i need 4 wagoneer/chevy calipers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 13th, 2012, 04:11 PM   #1
Wramblerguy
Wramblerguy's Avatar
Default i need 4 wagoneer/chevy calipers
ok i just looked at the price of a new one and its 12.99....plus a 18.00 core charge
so i need 4 calipers if they are functional i will pay more
as well as all the rest of the hardware, i will buy new pads but it would be cheaper the less new parts i need
all i have is the bracket on the axle
and this is for a late model drivers drop axle if that makes a diference
and the closer to the west side (kalamazoo) the better
tell me what you have thanks
1/2 or 3/4 ton chevy of the same style will work as well
Old July 13th, 2012, 09:09 PM   #2
addicted
addicted's Avatar
Pretty much any cast iron, GM, single piston caliper will be the same. If you are just wanting them for cores you could use the smaller metric calipers used on S10's and the like. Most parts counter monkeys will never notice the difference.
addicted is offline   Reply With Quote
Old July 13th, 2012, 09:26 PM   #3
Wramblerguy
yes i forgot to add that
im doing discs all around and i just need 4
functioning ones would be best but i would give a couple bucks for a core
Old July 13th, 2012, 09:52 PM   #4
addicted
addicted's Avatar
And for a cheap upgrade you can use the GM 3/4 ton JB7 front calipers. Bigger piston for a little more apply pressure. Bolts on just the same. If you want to use the bigger pads they are a bolt on too.
Old July 13th, 2012, 10:21 PM   #5
dreezy
Haggard Fab
dreezy's Avatar
Good to know.
Old July 17th, 2012, 11:04 PM   #6
Wramblerguy
bump
Old July 19th, 2012, 07:01 PM   #7
Wramblerguy
up
Old July 31st, 2012, 10:31 PM   #8
Wramblerguy
i might be going to buy new parts on thursday and would need some cores
Page generated in 0.17652 seconds with 47 queries
