my new rig - 2011 KOH buggy, and wheeling pics from Johnson Valley, CA - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 12th, 2012, 11:46 AM   #1
knaffie
knaffie's Avatar
Default my new rig - 2011 KOH buggy, and wheeling pics from Johnson Valley, CA
On July 5th, I drove down to Johnson Valley, CA (where they run King of the Hammers) for a test drive and purchase of my new rig. My expectations were very high, and I'm delighted to say that this thing exceeded my expectations. What so many refer to as "just a stock LS1" made more than enough power to keep me happy (at least for now). The suspension was amazing. We were able to hold 50-60 mph over 2-3' whoops with no issues. It crawled amazingly well, especially with the sticky Krawlers. I love the way the dual Magnaflow mufflers sounds, especially at WOT. Everything about the car worked awesome.
It was loaded on the semi in LA yesterday. Hopefully I'll have it tomorrow.
I have plans to change a few things. First thing is that in the next couple week, five brand new Raceline wheels will be arriving. The ones on it (and the black steel spare shown) are being replaced under warranty. I had Nate remove the $$$$ race radio and GPS package and I've purchased a new Rugged Radio Intercom set. I'm going to leave the gargantuan 34 gallon fuel cell, at least for now. I did not purchase the back seat, but I did purchase the 14 gallon fuel cell that goes in there. I'm going to have a rack built over top of the fuel cell so I have a place to put tools, a cooler, gear, etc. I have a 3 quart accumulator I'm going to have installed to protect the engine from oil loss on inclines. I have 8 new HID lights on the way, but I'm not sure how many of them will make it on there or where I'll put them. I have tentative plans for a new wrap, but I have no idea what I want yet (ideas are welcome). Beyond that, its just little ideas here and there.
This car was not built for KOH, but it was raced in 2011. It as built by Rick Mooneyham (aka EZ Rick), owner of Trick Toys Fab and "borrowed" from the owner for the race. They ran 2nd place for quite a while, even while battling problems with fuel cell foam plugging the fuel filter. They broke a rear axle shaft ($$$ Superior 14 bolt shaft) on back door, and by the time that was replaced, they fell back to and eventually finished in 25th place. Still very respectable for a car of this caliber, considering how many of the cars it was competing with were built.
Specs:
Chassis- TTF (Trick Toys Fab) Crawl-rite 4 Chassis, 1.5" DOM with .188 sub-frame, .156 exterior tubes, and .120 interior tubes, 1/8" AL roof, 1/2" UHMW boat sides and bottom
*** Car dimensions*** 111" Wheelbase with 83" track width front, 80" width rear, 70" tall at ride height with 20"ish belly, I've never weighed car but race-ready should be sub 4K pounds...
Motor- LS1 (from 2002 Camaro SS) with 5 wire harness and flipped intake so the air filter is in the car breathing clean air, Bosch 044 fuel pump, Turnkey Engine Supply Pre-filter, Corvette style filter/regulator, Turnkey Engine Supply high mount alternator and bracket, fuel lines and fittings are all AN with push-loc high pressure hose
Trans- Built TH350 with upgraded clutches, compression braking, and RMVB, B&M shifter, and a huge Fluidyne cooler that keeps the transmission under 150 degrees...always! Transmission lines and fittings are all AN with push-loc high pressure hose
Transfer Case- Atlas 4.3 with 32 spline outputs
Front axle- Fully Custom high pinion Solid/Rock Crusher housing with Reid C's, Solid Knuckles and high steer, Solid hubs and Chevy 1/2 ton brakes, Detroit with 5.38 gears and Superior 35 spline chromo shafts (best chromo shafts you can buy) clearanced to 50 degrees by Branik, Longfield D60 300M u-joints, Detroit Locker
Rear Axle- Trussed OG 14 bolt with a shave, 5.38 gears and an RD114 ARB locker. Chevy 1/2 ton brakes
Front Suspension- Triangulated 4 Link with 1.5 uppers and FK 7/8" Heims, 2" Heat Treated Chromo lowers with FK 1 1/4" Heims, Fox 14" 2.5 Coilovers with reservoirs and dual rate springs
Rear Suspension- Triangulated 4 Link with 1.5 uppers and FK 7/8" Heims, 2" Heat Treated Chromo lowers with FK 1 1/4" Heims, 16" Fox 2.5 Coilovers with dual rate springs and Fox 16" 2.5 Triple Bypasses
Steering- Full PSC race hydraulic setup, high performance N-pump, orbital, 10" double ended ram for 50 degree steering, Derale steering cooler, and all synthetic Amsoil fluids
Driveshafts- High Angle Driveline 1350 shafts with CV shaft in the front
Wheels - (5) 17" Raceline Monsters with AL rings
Tires- (5) 39" BFG Krawlers...4 tires are 95%, spare is about 30%...
Gauges- Autometer Carbon series gauges (Tach, fuel, oil pressure, water temp, volts, and trans temp), 12 Volt Guy switch panel with remote winch control
Winch- Narrowed Warn M8000 with Amsteel Blue synthetic line
Front Seats- PRP Comp Highbacks with DJ Safety Harnesses
Fuel Cell- Jaz 32 gallon race fuel cell (new after KOH '11) with new foam for racing and a 14 gallon aluminum cell that fits behind the rear seat for when you want to play on the trail with the family
Extras- Window nets, (2) Parker Pumpers (new), spare PSC steering N-pump (new), spare Bosch 044 fuel pump and fuel filter/regulators (both new), Wilwood Master cylinder/brake pedal, CNC dual handle turning brakes, hydraulic valve parking brake, ARB air compressor, steel braided brake lines and ARB line
Anyway (enough babble), here she is.
Old July 12th, 2012, 11:47 AM   #2
knaffie
knaffie's Avatar
Old July 12th, 2012, 11:53 AM   #3
Strangler
Strangler's Avatar
Nice rig. Did you sell your truck?
Old July 12th, 2012, 11:56 AM   #4
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
must be sweet out there without all those KOH fucks
Old July 12th, 2012, 11:57 AM   #5
knaffie
knaffie's Avatar
It's still mine, but I have received a deposit for it and my PJ trailer. It's getting a little work done on it right now after a rough trip to Silver Lake, then the new owner should be picking it up in early September. He's out shopping for a tow rig now.
Old July 12th, 2012, 11:59 AM   #6
knaffie
knaffie's Avatar
It was a fun 1/2 day of wheeling. We didn't see a single other person the whole time. But, I could never live out there.
Old July 12th, 2012, 12:00 PM   #7
trailrail302
Im going FAST!!!
trailrail302's Avatar
Damn, Nice rig!
Looks different out there with out all the dust...lol
trailrail302 is offline   Reply With Quote
Old July 12th, 2012, 12:04 PM   #8
curbdog17
Mini Van
curbdog17's Avatar
Bad ass
Old July 12th, 2012, 12:08 PM   #9
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
Very nice looking buggy...What are the plans for it? Racing it or just Rec use?
NitzPixs is offline   Reply With Quote
Old July 12th, 2012, 12:10 PM   #10
knaffie
knaffie's Avatar
There's no way I could race it. My job wouldn't allow that. Just recreational wheeling. Already have several trips planned for this year - rocks, sand, trails, and anything in between.
Old July 12th, 2012, 12:33 PM   #11
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Very nice!! I hope to get something like that in a few more years......
RIP FULLSIZE4LIFE
Old July 12th, 2012, 12:37 PM   #12
silveradoboy
Sam Brown
silveradoboy's Avatar
Are you going to join the 1% now?
Very nice rig!
silveradoboy is offline   Reply With Quote
Old July 12th, 2012, 12:38 PM   #13
knaffie
knaffie's Avatar
Sorry, I don't get it.
Old July 12th, 2012, 12:42 PM   #14
silveradoboy
Sam Brown
The 1% Hardcore wheelers of Michigan - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 12th, 2012, 01:19 PM   #15
I wondered if I'd see this over here or not.
Old July 12th, 2012, 01:38 PM   #16
alumcj
alumcj's Avatar
those KOH guys are doing alot to keep that awesome place open to the public....i suspect if it were not for KOH the fund supporting keeping that place open wouldn't have 10% of the money it does.
nice rig btw! im sure the shocks are dialed in perfect....Rick is FAST!
alumcj is offline   Reply With Quote
Old July 12th, 2012, 01:41 PM   #17
KOH qualifier this weekend at the badlands
Old July 12th, 2012, 01:43 PM   #18
knaffie
knaffie's Avatar
Yeah, everything I read said Rick really knows his shit. Nate told me that the reps from Fox helped them get everything tuned in a couple days before the race. Not that I have anything to compare to in a comparable car, but the ride is pretty amazing, whether fast or slow. I about shit myself when he was doing about 50 and didn't let up with a bunch of 3' whoops in front of us. It soaked them right up. And he said they ran 70+ on those same bumps at race speed.
Old July 12th, 2012, 01:43 PM   #19
knaffie
knaffie's Avatar
Yeah right.
Old July 12th, 2012, 01:48 PM   #20
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Nice rig. EZ-Rick may talk a lot, but he definitely backs it up. I'm jealous.
Page generated in 0.45639 seconds with 84 queries
