FJ40 Frame Boxing Kit.....! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2012, 07:36 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow FJ40 Frame Boxing Kit.....!
These are Reinforcement Plates to box the rear of your FJ40, they are .1875" (3/16) thick Steel Plate. Made to strengthen an inherently weak area on an FJ40, opinions differ on whether or not Boxing the frame should be done so do your research. We believe the frame should be stiff and the suspension should be doing the flexing. Flexing the frame loosens the rivets and slowly tears it apart. This comes with a 1.75" x .120" replacement crossmember with 4 predrilled placement options, one of the holes is at the stock position and the others are spaced 3" on center, one in front and 2 behind the stock position. If you are adjusting your WB way back we would recomend 2 Crossmembers to retain the structural rigidity gained by the frame boxing itself and the Crossmembers provided are long enough to allow mounting through the existing frame also (just drill 1.75" holes through the frame using the Plates as a guide). These are designed to fit within the frame itself so you do not have to remove the tub to install, however you do have to remove the factory Crossmember and mounting plate and reposition the rear brake line. The short angled plates are made 1/8" long to allow for movement that has already occured. Welding Required!
This is really a pretty simple kit, I will add a couple of good pics of one on a frame ASAP......
http://www.ruffstuffspecialties.com/...FJ-BOXKIT.html
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old August 6th, 2012, 03:38 PM   #2
Gravel Maker
Steel Hauler
Thumbs up FJ40 Frame Boxing Kit.....!
The best way to add some beef to that FJ 40 !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 6th, 2012, 06:41 PM   #3
Gravel Maker
Steel Hauler
The right way to box that rear !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Page generated in 0.19854 seconds with 32 queries
