D60 Full Float Rear Axle Flanges! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2012, 06:29 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Smile D60 Full Float Rear Axle Flanges!
Something new for us at Ruffstuff! I tried to buy these from another vender but he wanted more than what I am willing to sell these for so we had to make them ourselves and improve them along the way ;)
These are unique in that they will both work for Chevy or Ford D60 front spindles. The Ford will have a small spacer but that isn't ready yet, the Chevies are good to go! They are also made to clear the biggest of calipers.
So far we only make these with a 3.5" opening but the 3.25" are on the way!
The way we made them less expensive is all in the machinists' methods and these were made for us by Kyle at NWF. Kyle has a pretty good idea of the best ways to do things. The end result is what counts but the way you get there is what you end up paying for.
With these you can easily use a 35 spline shaft on the rear using common D60 front axle parts. I see these as a great way to use a 9", Sixty9, Solid14, or Torq rear third member and minimize your spare parts needs by using what you already use on the front axle.
These are made from 44W 1" Plate and machined for a press fit. They are $160 a pair for as long as we can afford it but we have 40 pair on the shelf as of today :) These are the new industry standard!
http://www.ruffstuffspecialties.com/.../FLANGE60.html
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old August 7th, 2012, 01:36 PM   #2
Gravel Maker
Steel Hauler
Arrow D60 Full Float Rear Axle Flanges!
The best way to upgrade your current rear end !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 11th, 2012, 03:29 PM   #3
Gravel Maker
Steel Hauler
A great upgrade for semi float axles !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Page generated in 0.18457 seconds with 32 queries
