Ruffstuff 3 Link Kit! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2012, 07:23 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Ruffstuff 3 Link Kit!
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat & Cryo Treated Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs and another set of the same in 7/8" for the Panhard. We add our Chassis Link Brackets, a 10 degree Adjustable Axle Link Tower, a 10 degree Adjustable Frame bracket for the 3rd link, the Axle Lower Link brackets. We finish the Kit off with the Panhard setup, an Axle Offset panhard Bracket & the Frame panhard (Inside or Outside).
We do not include the tubing because you will save alot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot! If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
These are $573 and $23 to ship, sound fair to you?
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old August 22nd, 2012, 02:53 PM   #2
Gravel Maker
Steel Hauler
Time to do it right !! Lose them leafs !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 18th, 2012, 03:02 PM   #3
Gravel Maker
Steel Hauler
A great way to do the front end !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 13th, 2013, 08:19 PM   #4
Gravel Maker
Steel Hauler
Time to give your rig the articulation it needs!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old May 17th, 2013, 12:27 PM   #5
Gravel Maker
Steel Hauler
A 3 link kit is just what you need!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old June 5th, 2013, 04:07 PM   #6
Gravel Maker
Steel Hauler
Give your rig the flex it needs!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old July 22nd, 2013, 03:25 PM   #7
Gravel Maker
Steel Hauler
Take down the best with the best!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old July 29th, 2013, 10:37 AM   #8
Gravel Maker
Steel Hauler
Hope everyone had an awesome weekend!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old July 29th, 2013, 02:46 PM   #9
dirtydude
dirtydude's Avatar
Whats Your Bottom Dollar?
dirtydude is offline   Reply With Quote
Old July 29th, 2013, 02:59 PM   #10
Gravel Maker
Steel Hauler
This isn't a swap meet and its not like I only have one...
However, if you plug in GL4X4 in the discount code box you will get another 10% off ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Page generated in 0.33889 seconds with 53 queries
