rear pinion angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2012, 08:47 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default rear pinion angle
Had it perfectly at -2* of the yoke pointing down with my rear YJ leaf SOA CV shaft. Welded it all up, took it for a spin and rechecked to find its +2* now. What gives?
I hope I can just raise the tcase to take up the difference.
Old July 10th, 2012, 09:21 PM   #2
cerial
Direct Drive FTW
cerial's Avatar
Did you have the vehicles weight on the axle when you were setting the pinion angle?
Old July 10th, 2012, 10:52 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I sure did. Just can't figure out where I went wrong. I even had the axle center, then after getting it all done its 1/8" off to the driver side. I can't win lol. I guess 2 positive is better then the 5 it use to have before cutting the old perches off.
Would longer shackles or boomerang shackles help fix this in any way??
Old July 11th, 2012, 05:09 AM   #4
Did you have your u-bolts tightened up? There is more arch in your springs in a free state. Plus, you need to jump up and down on the bumper to seat the springs. Just dropping the jeep off the floor jack is not enough.
Longer shackles will make it worse, not better. If it's truly only +2 you are probably OK if the rest of the build is stout.
Old July 11th, 2012, 11:06 AM   #5
x2
Old July 11th, 2012, 12:26 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Dang. Ubolts were snug so I could rotate pinion. I'll raise tcase to offset it. Thanks guys! Its better then the 5* it use to be.
Old July 11th, 2012, 12:30 PM   #7
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Degree shims/wedges
Old July 11th, 2012, 12:52 PM   #8
deerebowtie
Unchained
deerebowtie's Avatar
is the parking spot level?
Old July 13th, 2012, 04:44 PM   #9
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Why would you want your pinion pointing down?
Old July 13th, 2012, 11:07 PM   #10
deathbypsi
Brian R.
deathbypsi's Avatar
Do you have a cardan joint at t-case?
Page generated in 0.29694 seconds with 53 queries
