removing valve springs without removing heads ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2012, 12:15 AM   #1
junkjeep
junkjeep's Avatar
Default removing valve springs without removing heads ?
Im changing valve springs on a 1979 for 400cid and am not pulling the heads off, i have a tool to compress the springs and to presurize the cylinder but am simply wondering how much psi to put in the cylinder? Thanks
junkjeep is offline   Reply With Quote
Old July 10th, 2012, 12:19 AM   #2
boggin-machine
boggin-machine's Avatar
why not do it the correct way and check the cross hatch on the cylinders and replace the gaskets. its not that expensive for a set of gaskets.
Old July 10th, 2012, 12:19 AM   #3
jaysusr
jaysusr's Avatar
Put all the psi in.
Old July 10th, 2012, 12:29 AM   #4
junkjeep
junkjeep's Avatar
Because the motor was a recent crate motor install, im just throwing in a cam, valve springs, double roller chain, hi volume oil pump, alum intake, 4bbl carb and header before the silver lake trip
Old July 10th, 2012, 12:30 AM   #5
junkjeep
junkjeep's Avatar
Originally Posted by jaysusr View Post
Put all the psi in.
Lol i cant spell -- edit below --
Old July 10th, 2012, 12:32 AM   #6
junkjeep
junkjeep's Avatar
Put all the psi in.
Thanks jaysusr
Old July 10th, 2012, 12:35 AM   #7
boggin-machine
well since your already going to have the headers and intake off just pull a few more bolts and do it right.
Old July 10th, 2012, 05:08 AM   #8
Yota Bill
There is nothing wrong with pulling the springs without pulling the heads. Pulling the heads to do it is not necessarily "doing it right".
Air pressure can be as low as about 75psi or so, but just leave it at whatever pressure you run your shop at (125 or so). Also be careful not to tap the valves with the springs removed. If it breaks the seal on the seat, the valve may drop, and you will be pulling the head then.
Old July 10th, 2012, 05:31 AM   #9
Cool parts peddler
Ironman Offroad's Avatar
Agreed.
Old July 10th, 2012, 09:49 AM   #10
bdd1469
bdd
bdd1469's Avatar
By doing it right you mean wasting time and money,along with lifting those heavy heads out of the truck?
Instead of using air you can also use a lenght of soft rope,feed it in through the plug hole and bring that piston to tdc.The rope will squish between the piston and valves,holding them in place.
This takes a little longer then air,but you dont need to worry about losing airpressure when your buddy walks in the shop and unhooks your air hose to fill his tire.
Old July 10th, 2012, 09:52 AM   #11
When you inject the air, sometimes it rotates the motor, don't have your breaker bar or rachet attached to the balancer bolt at that time .
Old July 10th, 2012, 10:22 AM   #12
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I set each cylinder at tdc when doing it this way. That way if the valve drops you can still get at it.
Old July 10th, 2012, 09:20 PM   #13
junkjeep
junkjeep's Avatar
i used shop air and it worked like a charm, my grandpa actually told me about the rope thing a while back but have never tried it
Old July 10th, 2012, 10:10 PM   #14
GREASYHANDS
GREASYHANDS's Avatar
I don't like rope. I did it that way a few times. Once the rope snagged on the spark plug ( I assume ) and caused a miss fire. Shop air has always worked flawlessly for me after that.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 10th, 2012, 10:39 PM   #15
hamsmotorsports
hamsmotorsports's Avatar
How would it snag the plug if it was out? That said I always use air.
hamsmotorsports is offline   Reply With Quote
Old July 11th, 2012, 07:35 AM   #16
GREASYHANDS
good question. Maybe it was on a 4cly ranger with 8 plugs.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 11th, 2012, 11:02 AM   #17
hamsmotorsports
Or maybe this two plug hemi I'm doing right now.
Old July 11th, 2012, 11:30 AM   #18
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Ive done air and rope. with air I was always nervous that the valve could drop, esp. when trying to get the spring and retainer lined up. with rope there is no worry. use a soft rope like cotton sash cord. stuff alot in and leave about a foot out
Old July 18th, 2012, 12:46 AM   #19
junkjeep
junkjeep's Avatar
using shop air i used a very crudely built homemade tool to compress valve springs that had to be held down by hand the whole time and it would bind up against the valve and i didn't have one valve even seen to want to break seal ? maybe i got lucky this time
Old July 18th, 2012, 12:50 AM   #20
junkjeep
junkjeep's Avatar
you'd think so but i know a mechanic that knocked one in and the piston wasn't on tdc so by using 2 magnets, 1 through the valve hole and one through the spark plug hole (while the engine was still in the vehicle) he managed to get the valve back where it belonged lol
Page generated in 0.28512 seconds with 83 queries
