trans / t-case combo's ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 17th, 2006, 07:31 AM   #1
mehoffine
Default trans / t-case combo's ?
Currently a 727 with an NP208. What other t-cases will match up without changing anything else?
Will the tranny output shaft have to be changed?
Will the trans-tcase adapter need changed?
Thanks.
mehoffine is offline   Reply With Quote
Old October 17th, 2006, 08:14 AM   #2
Chop
Mischievous Badger
Chop's Avatar
Thanks.
what year truck is it out of? i would think a 205, d300...... should bolt up depending on your spline count
Old October 17th, 2006, 08:45 AM   #3
PavementPounder
PavementPounder's Avatar
Anything with the round NP mounting pattern and the same spline count. D300, etc... That 208 should have fixed yokes - not really a bad case to have. Shorter than a 231, no slip yoke, and a beefier chain. Wrong drop for you?
Old October 17th, 2006, 10:34 AM   #4
mehoffine
I was looking for the 727 / 203 combo for a doubler set-up. The 203 is not a round pattern I know. Although this tranny might work in another vehicle that will not be a doubler set-up. Thanks for help.
Old October 18th, 2006, 04:13 PM   #5
user name
keep your stick onthe ice
user name's Avatar
they did put a 203 behind a 727 but i think it was a different main shaft in the trans.
Page generated in 0.29533 seconds with 38 queries
