frame repair - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2012, 06:46 PM   #1
Derek B
Redford
Derek B's Avatar
Default frame repair
Ok so Spudy and I are going to be welding the good front 1/2 of the frame under my tj. To the good back 1/2 of a frame I got last week. Looking to see what others have done for this as cutting goes and welding it. Post or message me or Spudy.
Derek B is offline   Reply With Quote
Old July 8th, 2012, 08:13 PM   #2
Derek B
Redford
Derek B's Avatar
Any help with this would be nice
Old July 8th, 2012, 08:23 PM   #3
firehawk
Live Action!
firehawk's Avatar
Google is your friend my friend.
Old July 8th, 2012, 08:31 PM   #4
jhnyquest
goof ball
jhnyquest's Avatar
Same models of jeeps?
Old July 8th, 2012, 09:52 PM   #5
How's the material thickness on the original half of the frame? The frame isn't real thick to begin with, and they rust out bad from the inside.
The generally accepted process is to weld the frame back together first, then weld on plates that go a few inches each way past the seam, that are as tall as the frame (so about 3.5" tall on the TJ, since the frame is 2.5 x 4 but has radius on the top and bottom. most people make the ends diamond, rounded, fishmouths, etc, for fear of vertical seams cracking.
This is what I've done on my lengthened TJ frame under my CJ6. I was surprised how must the rust had thinned the frame from the inside.
Old August 28th, 2012, 06:36 PM   #6
DatcKid
Welding/splicing the frame can be tricky...mainly on vertical welds in high stress areas
Few terms to search before you start...
Heat/stress riser
"z" cut
Fishmouth plate
You also want to make sure you're material thickness is relatively close...thicker material will act like a heat sink and pull the heat out of the thinner faster than two pieces of the same thickness...could potentially make the thinner metal extra brittle (crack with frame flex)
DatcKid is offline   Reply With Quote
Page generated in 0.16433 seconds with 41 queries
