polaris scrambler question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2012, 08:20 AM   #1
waynejaynes
waynejaynes's Avatar
Default polaris scrambler question
Im heading to silver lake and my trailer will only haul 2 ATVs. but im hauling 3 this time. can i stand them up on end to make more room? Im thinking if i do the oil and antifreeze will leak out? anyone try this before?
waynejaynes is offline   Reply With Quote
Old July 8th, 2012, 09:31 AM   #2
GREASYHANDS
GREASYHANDS's Avatar
I've seen this done many times, not sure how good it is for leaks but its possible
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 8th, 2012, 10:06 AM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
^ x2. I've also seen guys take a couple sheets of 3/4" plywood and slide them under the 2 front quads to hold the wood down and then park the last quad sideways on the back.
Usually 2 tires are still on the trailer portion and 2 on the wood.
strap everything down really well and check things frequently.
Old July 8th, 2012, 10:45 AM   #4
Elusive
Elusive's Avatar
Hopefully it isn't one of those 2 place aluminum snowmobile trailers with the tiny tires. Years ago my buddies and i crammed 3 atv's and a small generator on one, and the wheel bearings gave out after 2 hours.
Elusive is offline   Reply With Quote
Old July 8th, 2012, 01:33 PM   #5
YFZdude
aka Mike
YFZdude's Avatar
I have stood two quads up on end to get them both into the bed of my 1500 pickup. Turn the gas off, of course, and oil should not be a problem. I've had no anti-freeze leaks but then again my quad isn't beat up much so that helps.
Most of the fluid systems are sealed. The carb is the only weak spot.
YFZdude is offline   Reply With Quote
Page generated in 0.20846 seconds with 39 queries
