Question on INTAKE repair on a 5.2 Liter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2012, 06:49 PM   #1
Tex
Tex's Avatar
Default Question on INTAKE repair on a 5.2 Liter
I keep reading that there is many different ways to try to repair them do any of them really work? I did mine back around October and now have any issue with a #8 cylinder misfire. I have tested every thing and tried the rerouting of the wires and nothing has changed it. The only thing left that Ive come to is the intake is bad again according to Identafix. So is there a way besides welding the lower plenum plate that will keep me from having this problem again?
Tex is offline   Reply With Quote
Old July 7th, 2012, 08:28 PM   #2
Tex
Tex's Avatar
Any one on here ever ran into this issue cause from what i found on google to what Ive found here I get totally different input about what works and what doesnt?
Old July 10th, 2012, 10:10 PM   #3
Flat_Black
The Dodge Guy
Flat_Black's Avatar
http://www.hughesengines.com/Index/p...=&partid=27091
Old July 11th, 2012, 04:40 PM   #4
rammanriley
rammanriley's Avatar
Originally Posted by Flat_Black View Post
This^ you wont be sorry. Only other option is to buy a M1.
rammanriley is offline   Reply With Quote
Old July 15th, 2012, 02:34 PM   #5
pigfat
GONE COMMANDO
pigfat's Avatar
more than likely your injector is clogged. the fuel rail design is poor and the number 8 injecter because of its placement in relation to the rail has a tendancy to clog up. its real easy to fix. unbolt the rail, take off the throttle cable bracket,(i usually just take the throttle body off and put a new gasket on instead) remove the injector, look inside you will see a bunch of brown crap inside it. Clean it out with carb cleaner reinstall it and be on your way.
pigfat is offline   Reply With Quote
Old July 15th, 2012, 02:37 PM   #6
pigfat
GONE COMMANDO
pigfat's Avatar
Highly doubt its the gasket again, this early. they usually go bad from getting old and cracking, not really much else. the chances of your gasket being bad is highly unlikely. dont pull the intake until youve exhausted all other options.
Page generated in 0.20218 seconds with 41 queries
