98 ranger bucks and sputters when cold at higher rpms - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2012, 04:10 AM   #1
osnapchuckie
learn after breaking...
osnapchuckie's Avatar
Question 98 ranger bucks and sputters when cold at higher rpms
My 98 ranger 3.0 5 spd jerks/ bucks/ sputters feels like a hard misfire at higher rpms when cold. After it warms up, you can't make it do again. Happens when you push past 2700rpms before shifting. I just did all the plugs and they are spotless. I did get codes for the egr system.
P1451 evaporated control system canister vent solenoid circuit malfunction
P0401 egr flow insufficient
p1400 dpf egr sensor circuit low voltage detected
I have replaced these...
egr valve
EGR pressure sensor
Plugs
Seafoamed the motor
It runs great and idles good just scares me with this issue.
Any help would be greatly appreciated.
osnapchuckie is offline   Reply With Quote
Old July 7th, 2012, 01:28 PM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
How does the EGR tube look? no rust holes?
Old August 24th, 2012, 08:24 AM   #3
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Had a ford tempo that did something like that. Ended up being a bad coolant temp sensor sending bad info to the computer. Screws up the fuel management.
Old August 24th, 2012, 08:40 AM   #4
osnapchuckie
Egr tube is fine. Ill give the coolant temp sensor a try this weekend and see if that has any affect.
Thanks
Page generated in 0.20144 seconds with 35 queries
