Gearing running 44s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 4th, 2012, 12:01 AM   #1
Jgb
Default Gearing running 44s
If I'm running 350 headers 4 brrl and cam what should I run for gears to run 44s? Thanks
Jgb is offline   Reply With Quote
Old July 4th, 2012, 01:55 AM   #2
2fst4you
2fst4you's Avatar
How much power does the motor make?
What will the rig be used for?
What axle are you running?
Old July 4th, 2012, 05:54 AM   #3
Cool parts peddler
Ironman Offroad's Avatar
5.38's would help that small block roll those meats,
Old July 4th, 2012, 06:01 AM   #4
curbdog17
Mini Van
curbdog17's Avatar
x2
Old July 4th, 2012, 12:07 PM   #5
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
what tcase?
4x4xdodgeman is offline   Reply With Quote
Old July 4th, 2012, 12:48 PM   #6
koochman450r
koochman450r's Avatar
I have 6.72 I shouldn't have a problem. There are more variables than just axle gears. What trans, what t case, doubler, all that makes a huge difference.
you won this battle.
koochman450r is online now   Reply With Quote
Old July 4th, 2012, 05:22 PM   #7
bigblockford79
Big Block Ranger
bigblockford79's Avatar
It also would depend on what the intended use is going to be, for mud and sand 5.38 gears and a t-case with a 2.76:1 low will give you decent usable power. Keep in mind that 44" tires create massive rolling resistance especially in mud or sand. If you require wheel speed for your application you might need more HP since a small block will struggle in high range with that large a tire in pretty much any off road terrain. If you're into rocks and technical wheeling where high wheel speed isn't necessary a doubler should be on your list of future purchases.
I run 42's / 5.13 gears, an np205 (1.96 low) with a slightly built (350-400hp) big block and there are times that I could use lower gearing.
Old July 5th, 2012, 09:02 PM   #8
Jgb
Thanks for replys, not really sure on hp numbers but just looking at gear options, trucks going to be just mud truck and maybe dunes, but also been considering big block, just a project and tossing ideas around.
Page generated in 0.27436 seconds with 47 queries
