Ford vs. Chevy Dana 60 SRW Hubs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2012, 06:36 AM   #1
John D
John D's Avatar
Default Ford vs. Chevy Dana 60 SRW Hubs
It seems obvious there must be a difference in the Ford SRW hub and a Chevy due to the different spindle length, and after reading the D60 bible 10x along with every thread I could find most people agree. However, I can't find where anyone describes how to tell the difference between the two.
Here's my dilemma. I picked up an 86-88 Ford king pin Dana 60, originally came with DRW. What I got was an empty housing, knuckles, spindles and some SRW hubs. I plan to turn down the hubs and convert them to 5x5.5 wheel pattern to match my 9" rear. The problem is I cannot determine if the hubs are actually Ford. I need this info before I can spend the money to re-work the hubs.
Any thoughts or ideas on how to tell the difference? There must be a way to measure the hub, but I don't know what it is.
Thanks,
John
Old July 3rd, 2012, 09:35 AM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
The chevy spindle, hub and outer shaft are about 5/8" longer than the Ford stuff. My Ford D60 front hubs are 5.25" wide FYI
Old July 4th, 2012, 06:08 AM   #3
John D
John D's Avatar
Are they of the axle right now? If so, can I get you to check a couple more measurements?
Old July 4th, 2012, 07:56 AM   #4
bigblockford79
Big Block Ranger
Yes, let me know what measurements you need.
Old July 4th, 2012, 08:38 AM   #5
John D
John D's Avatar
These aren't perfect measurements, but it should reveal if it's the same or 5/8" difference.
Using a tape measure going in from the outside of the hub (where the lockout flushes w/the hub) to the outer edge of the outer bearing cup I measure 2 7/8".
From the back side of the hub to the outer edge of the inner bearing cup I measure 7/8".
How does yours compare?
Thanks,
John
Old July 4th, 2012, 09:07 AM   #6
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Just a thought, go down to napa and ask to see both.
Old July 4th, 2012, 10:12 AM   #7
John D
John D's Avatar
I'll ask when I go there tomorrow, but from everything I have read it is unlikely NAPA will carry them. GM parts direct, Six States, and a host of other after market vendors is the only places I have seen for new ones.
Old July 4th, 2012, 04:56 PM   #8
bigblockford79
Big Block Ranger
I measured my hub and got the same measurements as you, so you indeed have Ford hubs.
Old July 4th, 2012, 08:39 PM   #9
John D
John D's Avatar
Thank you sir, I appreciate the help.
John
Page generated in 0.29272 seconds with 50 queries
