$25 Each AXLE ASSEMBLIES--SCRAP YARD NEXT WEEK - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2006, 08:53 PM   #1
JKOZ
yes
JKOZ's Avatar
Default $25 Each AXLE ASSEMBLIES--SCRAP YARD NEXT WEEK
UPDATED LIST
These are in Midland, MI 48642 and will NOT ship any of them.
ALL AXLES $25 EACH---as is, we will not check for gear ratios. The are all good rebuildable axles.
FYI---we are cleaning up the yard preparing for a major business re-structuring / move / etc.
Item # Description of REAR axles Cost
120 D44 5 on 5.5 complete 58" wms
123 D60 8 lug complete 68"
124 D60 8 lug complete 66"
125 D60 8 lug complete 64.5"
127 D60 8 lug complete 64"
128 D35 YJ complete 3.07gear
Descriptions of FRONT axles
200 D44 HP 1/2 ton cast in c's, has long side shaft everything else gone
202 D44 HP 1/2 ton cast c's no shafts or outers
203 D44 HP 3/4 ton has kuckles--everything else is missing
207 D30 low pinTJ/XJ/ZJ cv-short side broke, no rotors/calipers 3.73
208 Chevy 10 bolt 6 lug complete
209 D30 HP TJ/XJ/ZJ its a disconnect axle Complete
210 D50 Superduty housing and inner shafts only
JKOZ is offline   Reply With Quote
Old October 16th, 2006, 10:07 PM   #2
DodgeitRamit
DodgeitRamit's Avatar
What are the gear ratios on the 2 complete Dana 44 HP 8 lugs front axles?
DodgeitRamit is offline   Reply With Quote
Old October 16th, 2006, 10:31 PM   #3
Pete M
Comanche Addict
Pete M's Avatar
How about the ratios in the Ford half-ton fronts?
--Pete
Pete M is offline   Reply With Quote
Old October 16th, 2006, 10:46 PM   #4
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
Are these axles at the shop?
if so I will be calling tomorrow about a couple.
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old October 16th, 2006, 10:58 PM   #5
Grandman
do i look old !
Grandman's Avatar
I have dibs on a 44 seems i called you on it . check you pms
Old October 17th, 2006, 07:07 AM   #6
BigBlueBurban
Temporary Web Wheeler
BigBlueBurban's Avatar
Ford D44 HP 3/4 ton leaf sprung 8 lug complete $200
Would you be willing to ship or is it pick up only? Interested.
BigBlueBurban is offline   Reply With Quote
Old October 17th, 2006, 08:45 AM   #7
JKOZ
yes
JKOZ's Avatar
I can ship it if you want, in michigan it should be under $100 for shipping
Yes they are all at the shop
I'll call you when I'm done typing this message
I'll see if I can find tags for gear ratios.
Old October 17th, 2006, 11:53 AM   #8
Wehan
Wehan's Avatar
Gear ratio in D30's? looking for 4.10
Ship to 48813?
Wehan is offline   Reply With Quote
Old October 18th, 2006, 05:02 PM   #9
JKOZ
yes
JKOZ's Avatar
Btt
Old October 18th, 2006, 05:16 PM   #10
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
would it be worth any of the front 44s for my tj considering all the work involved and $? any idea of how much it would end up being? after its ready to roll?
nate4d is offline   Reply With Quote
Old October 18th, 2006, 06:47 PM   #11
JKOZ
yes
JKOZ's Avatar
give me a call in the morning and I can put together a price for you on a complete assembly in a few minutes. Prices can vary drastically depending on what you want for all of the componets.
to answer your first question--yes the older HP44 axles are great donors for axle builds. Depending on what bolt pattern you want 8 lug or 5 on 5.5
Old October 18th, 2006, 07:04 PM   #12
Wingnut
Ready 4 Hockey 2 start
Wingnut's Avatar
Question 120 D44 5 on 5.5 complete 58" wms $75
Would this be able to hook up under a TJ w/out a bunch of mods?
Thanks!
~Wingnut
Wingnut is offline   Reply With Quote
Old October 18th, 2006, 08:33 PM   #13
rebelrat
turd hurdin jeeper
Default d30
im looking for unitbearings for my 89 xj????
any help
rebelrat is offline   Reply With Quote
Old October 18th, 2006, 10:14 PM   #14
Moose92
Many much Moosen
Moose92's Avatar
Interested in a 68" D60 and a 66" D60. Also one of the HP D44 Fronts.
Moose92 is offline   Reply With Quote
Old October 20th, 2006, 09:40 PM   #15
JKOZ
yes
JKOZ's Avatar
Thanks!
~Wingnut
Its a little narrower than the stock axle. If a disc brake set up was put on this axle it would make it 59". other than that some tj brackets and r&r gears / bearings etc.
Old October 20th, 2006, 09:40 PM   #16
JKOZ
yes
JKOZ's Avatar
any help
Nope
Old October 20th, 2006, 09:41 PM   #17
JKOZ
yes
JKOZ's Avatar
I belive we have already talked and you are planning on comming up tuesday. if thats wrong let me know. Thanks
Old October 23rd, 2006, 01:04 PM   #18
JKOZ
yes
JKOZ's Avatar
Btt
Old October 24th, 2006, 08:23 PM   #19
builtyj
is the dodge 60 front a closed or open nuckle?
builtyj is offline   Reply With Quote
Old October 26th, 2006, 07:49 PM   #20
disorder xj
Happy,happy,joy,joy
disorder xj's Avatar
Would like to know what you have left and would be good on my 1999 xj? 44/60 0r 60/60 same width both axles ,. Ill drive to pick them up.
disorder xj is offline   Reply With Quote
Page generated in 0.68077 seconds with 83 queries
