School me. D60 brakes. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2012, 07:16 AM   #1
03tjsport
Red Dragons!
03tjsport's Avatar
Default School me. D60 brakes.
I tried to find stuff,but don't really see anything like I have. D60 with no rear brakes. 5 on 5.5 bolt pattern. Has rotors but not sure from what. Got some Chevy 3/4 ton calipers and it looks like it may work. I just hate to order stuff to return it.
03tjsport is offline   Reply With Quote
Old June 28th, 2012, 07:17 AM   #2
03tjsport
Red Dragons!
03tjsport's Avatar
This shows the axle end. N/m picture won't load. Anyhow it looks like a normal axle shaft with no seperate hub,like its not a floater any more. My question is has anybody ran this and what brakes did you use?
Old June 28th, 2012, 05:27 PM   #3
addicted
addicted's Avatar
There are semi float D60's out there. Did you ask the guy you bought it from if he knew anything about the brakes? Got a link to the sale thread if there was one?
addicted is offline   Reply With Quote
Old June 28th, 2012, 05:33 PM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Where are u at in Howell? I could probably stop by and take a look
H.o.r.e
Old June 28th, 2012, 07:25 PM   #5
03tjsport
Red Dragons!
03tjsport's Avatar
That would be great,but right now the jeep is in Pinckney.
Old June 28th, 2012, 07:27 PM   #6
03tjsport
Red Dragons!
03tjsport's Avatar
I did scrape the gunk off the tube and found 12 19 7A2 for a build date and 60291 where the BOM is supposed to be. Not sure if there is more to that because there are some grinder marks there. I will try to look that stuff up later tonight. FWIW the front axle is a 44 with the same lug pattern and Ford calipers/knuckles/radius arms.
Old June 28th, 2012, 07:28 PM   #7
03tjsport
Red Dragons!
03tjsport's Avatar
No info from seller,he bought it the way it sits.
Old June 30th, 2012, 12:50 PM   #8
03tjsport
Red Dragons!
03tjsport's Avatar
Had another guy look at it. Says maybe a 60-2?
Old June 30th, 2012, 01:10 PM   #9
I suck cocks. Lots of them.
locally famous
rear 60's kinda suck, i wouldnt spend much on it. .02$
Old June 30th, 2012, 01:10 PM   #10
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Looks like a ford big bearing housing end. Not a 60-2 end they are round and 6 bolt i believe
Old June 30th, 2012, 01:49 PM   #11
03tjsport
Red Dragons!
03tjsport's Avatar
I think this may work: http://www.ebay.com/itm/Jeep-Dana-60...06%26rk%3D1%26
Old July 1st, 2012, 10:37 AM   #12
addicted
addicted's Avatar
They are round and 6 bolt. There is also the obvious 60-2 cast into the top of the gear housing.
Old July 1st, 2012, 11:10 AM   #13
03tjsport
Red Dragons!
03tjsport's Avatar
I don't have it here to check for casting on top. This has 4 bolts on the flange.
Old July 2nd, 2012, 10:22 PM   #14
03tjsport
Red Dragons!
03tjsport's Avatar
Not a 60-2,its not cast on the top. 4 bolt flange in a rectangular pattern.
Page generated in 0.26090 seconds with 65 queries
