First Time Off Road - What to watch out for - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old June 27th, 2012, 09:49 AM   #1
Jetson
Jetson's Avatar
Default First Time Off Road - What to watch out for
Hey Guys, I am thinking of going down to Bundy hills on Saturday. This would be my first off roading experience. Would like some tips on the to do's and not to do's either way am excited for this adventure
TJ Sahara, Off Road Tires, 3-inch lift
Jetson is offline   Reply With Quote
Old June 27th, 2012, 10:18 AM   #2
liv2mx
i like jungle gym's.
liv2mx's Avatar
stay away from the mud holes at the pond.
Old June 27th, 2012, 10:37 AM   #3
DuffMan
Your Message Here
DuffMan's Avatar
Stick with a buddy.
Water is not your friend.
Air down.
Make sure you have tow points front and rear - REAL tow points.
Have a strap with NO metal hardware.
Go slow, try different approaches, use your judgement. Don't get talked into doing something you're not comfortable with.
Get used to being off-camber - it feels strange at first.
Old June 27th, 2012, 10:53 AM   #4
wilsonjeepers85
wilsonjeepers85's Avatar
Never wheel alone it sucks to get stranded miles away from the nearest road pack a shovel tow strap and basic tools to replace ujoints and carry a jug with water for windshield or radiator
wilsonjeepers85 is offline   Reply With Quote
Old June 27th, 2012, 11:05 AM   #5
Jetson
Jetson's Avatar
Thanks guys .. will make sure to stay off water areas ... Need to get the strap without metal hardware
Old June 27th, 2012, 11:07 AM   #6
Jetson
Jetson's Avatar
Will carry the water. I gotta do it alone ..none of my frnds get 4x4. I just got my U-Joints done a month ago so hoping it will work fine.. will shop for a tow strap
Old June 27th, 2012, 11:24 AM   #7
wilsonjeepers85
I bought mine at tractor supply it was like 80 but will never brake when using it on a 2000# jeep
Old June 27th, 2012, 11:38 AM   #8
chasetheface123
chasetheface123's Avatar
I believe tractor supply has some $20 dollar ones right now...
chasetheface123 is offline   Reply With Quote
Old June 27th, 2012, 11:51 AM   #9
Don't get too big of a tow strap. For a jeep, a 30 ft, 20,000, 2" strap is what you want.
Old June 27th, 2012, 12:03 PM   #10
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
If there's a kid at the gate playing dueling banjos, just turn the fawk around and leave.
Old June 27th, 2012, 12:13 PM   #11
Jetson
Jetson's Avatar
lol.. alright fellas .. placed an order on Amazon for a Smittybilt Smittybilt CC220 2" x 20' Recovery Strap - 20,000 lb Capacity (http://www.amazon.com/gp/product/B00...ls_o00_s00_i00) for $20 .. I had prime so they ship for free
Old June 27th, 2012, 01:38 PM   #12
I suck cocks. Lots of them.
locally famous
dune flags, more the merrier
Old June 27th, 2012, 01:53 PM   #13
phittie1100
phittie1100's Avatar
When your strap comes in, pick a date for your first trip to BH and post it in a new thread here. There are like 47 gazillion members here, at least 11% of whom actually own a working 4x4 at any given point in time, sure you can find someone to go with.
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline   Reply With Quote
Old June 27th, 2012, 02:14 PM   #14
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
If you plan on wheeling alone often, get a high lift jack. It can be used as a winch or a jack and can be a cheap, usefull tool.
Get a spare tire too, never know if you might ruin one or take off a bead.
Old June 27th, 2012, 03:35 PM   #15
caveman
GeoDude
caveman's Avatar
just went there this weekend with a pretty much stock cherokee and went everywhere but warn valley and the tire/rock pit behind there. Just use common sense and you will be fine.
Old June 27th, 2012, 03:57 PM   #16
ronprice
ronprice's Avatar
Your fist time Scout it out try some basic stuff. Try to join up with someone esle. Off roaders are in most a friendly bunch. DONT!! give in to the GO FOR IT / BUMP it guys. at first, If not sure there is no shame in backing out.
ronprice is offline   Reply With Quote
Old June 27th, 2012, 04:03 PM   #17
Cool parts peddler
Ironman Offroad's Avatar
Support you local offroad shop.
There are able to give you great advice.
(Amazon does not have an advice dept.)
Old June 27th, 2012, 04:07 PM   #18
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Don't sit on the rev limiter trying to get through the mud. A lot of people do this, grab traction, and bitch that stock axles are junk while they are picking parts out the mud. Throttle control is important. It's not always a banzai run.
X2 on water, especially if you have an automatic. You will ruin an auto transmission dunking it under water. I'd also recommend following another Jeep that is about your size if you are green. Chances are pretty good on you making it if they do.
Old June 27th, 2012, 04:29 PM   #19
wilsonjeepers85
Make sure you have good breather tubes on your axles so you won't have to change fluids everytime you mudd
Old June 27th, 2012, 05:23 PM   #20
ronprice
ronprice's Avatar
Take a hot chick with you. You will have plenty of guys to wheel with then.
Post pic of said hot chick that may help too.
Page generated in 0.34997 seconds with 83 queries
