t case for a 00-01 grand with a 6 cyl - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2012, 09:18 AM   #1
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Default t case for a 00-01 grand with a 6 cyl
Mrs. Fullsize4life needs one, hers developed a hole it the case....what's out there
Old June 27th, 2012, 09:24 AM   #2
Mall Wheeler
RIP Collin
Mall Wheeler's Avatar
http://nmi.craigslist.org/pts/3062623911.html, not sure if this will work but just saw this posted on craigslist
Mall Wheeler is offline   Reply With Quote
Old June 27th, 2012, 09:33 AM   #3
Trail Junkie
iamfawkinwithyou
Thanks, looking into it
Old June 27th, 2012, 10:33 PM   #4
dmoney
tj on 36 iroks
dmoney's Avatar
Location: fremont michigan about hour north of grand rapids
Default I have 242 outta a 96 grand cherokee
If this will work 75$
dmoney is offline   Reply With Quote
Old June 28th, 2012, 06:45 AM   #5
Trail Junkie
iamfawkinwithyou
Anyone know if the 96 will work?
Old June 28th, 2012, 08:51 AM   #6
Wramblerguy
Wramblerguy's Avatar
There is still a couple options when it comes to transfer cases
It's either a 242,247 or 231 if my memory serves me right
And if it's the same as a zj it should work as long as the input shaft is long enough to meet the seal in the trans
Old June 28th, 2012, 06:46 PM   #7
dmoney
tj on 36 iroks
dmoney's Avatar
What does the tag tell you its on the back of the tcase like right in the middle it will tell u easy on take a pic of the tcase selector inside the car and we can figure it out
Old June 28th, 2012, 07:25 PM   #8
TJ get the last 8 of the vin from Courtney and I will look it up and know exactly which case it is.
Old June 29th, 2012, 02:37 PM   #9
jjoz05
BARE BONES OFFROAD
jjoz05's Avatar
Does it have 2wd or is it awd?
jjoz05 is offline   Reply With Quote
Old June 29th, 2012, 03:02 PM   #10
ajmorell
ajmorell's Avatar
The tailshaft/speedo housing is different on the WJ t-case since the speedo is read off of the ABS tone rings. It is probably possible to make an earlier TJ/XJ/ZJ case work by swapping the housing but I don't know for sure, probably easiest just to get one that'll bolt right up. I don't know if there were input shaft length differences on the WJ between the 4.0 and 4.7 like there were for the ZJ. There were 3 case variations available, the 242, 242HD (rare), and the 247.
Hope that helps a bit.
Page generated in 0.15715 seconds with 53 queries
