Dana 60 and Dana 70 in a TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2012, 10:46 PM   #1
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Default Dana 60 and Dana 70 in a TJ
New to the axle world. But have been wanting to upgrade my axles for a while now. I keep going bigger when it comes to tires and I constantly worry about the 30 under my jeep not being enough. I know one tons are in my future and know that they are a labor of love to install. That being said...
http://www.greatlakes4x4.com/showthread.php?t=240025
Would the 60/70 combo from this dodge be a good way to go?
I apologize for my rookie-ness.
Sent from my T-Mobile G2 using Tapatalk 2
Mihlfeldl2005 is offline   Reply With Quote
Old June 27th, 2012, 05:06 AM   #2
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
The front would be a CAD (central axle disconnect). It uses vacuum to separate the two piece axle shaft when the transfer case shifts from 4wd to 2wd. I'm not sure what would need to be done to make this axle work but I was steered clear of these when I was looking for an axle for a previous project.
BeaverTown is offline   Reply With Quote
Old June 27th, 2012, 05:51 AM   #3
BIGDANE36
BUY MY TRUCK
BIGDANE36's Avatar
Pretty sure dodge axles are low pinion and you wouldn't want that
BIGDANE36 is offline   Reply With Quote
Old July 16th, 2012, 09:55 PM   #4
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
price and your intentions for your jeep will dictate a lot.
what are your future plans ?
40's and a big block ?
Old July 16th, 2012, 10:25 PM   #5
deerebowtie
Unchained
deerebowtie's Avatar
ford hp 60 front, 14 bolt rear. depending on your shopping skills and the condition of the axles, expect to spend 400-700$ for these 2.
the front axle in your link is about 300$ over-priced.
Old July 17th, 2012, 09:34 AM   #6
Mihlfeldl2005
ended up getting a Ford Dana 60 Kingpin front out of a 1988 Ford F-350. Here's the current picture, i've been working my ass off on this thing and I just got the long side axle shaft cleaned up and slide it back in last night. Working on the short side tonight, I need to go pick up another U Joint. The one I got last night wouldnt let one of the caps slide off. Seems like it's
seized or something.
I also picked up a 14 Bolt rear. Should be a nice combination. I need to run 220v to my pole barn in the very near future though. Anyone know any good electricians?
Old July 17th, 2012, 10:14 AM   #7
iliveinhell2004
iliveinhell2004's Avatar
I can hook you up with one in your area.
iliveinhell2004 is offline   Reply With Quote
Old July 17th, 2012, 10:24 AM   #8
iliveinhell2004
I can't find his number, sorry. I should have looked first...
Old July 17th, 2012, 10:24 AM   #9
Strangler
Strangler's Avatar
BigBchevy on here has a buddy that wired my shop for a good price. PM him for James' #. Hes in Howell.
Page generated in 0.26003 seconds with 51 queries
