Pinion angles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2006, 02:09 PM   #1
DodgeitRamit
DodgeitRamit's Avatar
Default Pinion angles
Alright I am going to do an axle swap and I was wondering about the pinion angle. Right now I am doing the rear but plan on doing the front (Where the pinion angle prolly will matter more) but I was wondering how most of u guys would go about setting the pinion angle and what tools u use for it. I have 'lil more that 5'' suspension in back so thought while I have to relocate the perches I should probably point the pinion up a bit, but just a lil confused on how much and how to measure it info is appreciated thanks guys. Oh yeah and I was wondering where u can buy POR-15.
DodgeitRamit is offline   Reply With Quote
Old October 16th, 2006, 02:21 PM   #2
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
If you have a CV joint on the tcase end then point the pig right at it. If you just have single ujoints on both ends you should try to make the angles match as close as possible to help avoid vibrations.
Page generated in 0.17285 seconds with 29 queries
