Dana 30 gear install question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2012, 05:40 PM   #1
Spudy
Redneck Excavator
Spudy's Avatar
Default Dana 30 gear install question
Hey guys
Doing a dana 30 gear install on my 94 zj. It takes the cj gears. I found a set of used spicer gears online for sale. Picked up a master install kit and starting to do the swap. However i can not get the crush sleeve on the pinion. I searched the part number and everything looks right. The new crush sleeve looks just like the old on the old pinion but nothing fits the new.
Been searching online a bit and it looks like i have to convert my dana 30 from a crush sleeve pinion preload to a shim style preload. Can anyone confirm this? If so how do i do it?
Thanks
Spudy is offline   Reply With Quote
Old June 23rd, 2012, 05:57 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Pretty sure yes, just use the cj shims but you need a different outer pinion bearing
Old June 23rd, 2012, 06:07 PM   #3
babyjp95
average guy
babyjp95's Avatar
I thought U were doing that swap lat week? SLACKER!
babyjp95 is offline   Reply With Quote
Old June 23rd, 2012, 06:31 PM   #4
Spudy
Redneck Excavator
Spudy's Avatar
Only slacking as much as my help as been ok will have to look into it more
Old June 23rd, 2012, 06:31 PM   #5
Spudy
Redneck Excavator
Spudy's Avatar
Any idea on the bearing number i need?
Old June 23rd, 2012, 06:51 PM   #6
Jeepaholic
Jeepaholic's Avatar
Used to have it somewhere will look
Old June 23rd, 2012, 07:12 PM   #7
Jeepaholic
Jeepaholic's Avatar
m86647 cone cup should be same m86610 as stock
Old June 23rd, 2012, 09:48 PM   #8
Spudy
Redneck Excavator
Spudy's Avatar
So i need a m86647 bearing and a pinion shim kit correct?
Old June 23rd, 2012, 10:06 PM   #9
Jeepaholic
Jeepaholic's Avatar
Yes
Old June 24th, 2012, 09:02 PM   #10
Spudy
Redneck Excavator
Spudy's Avatar
was looking at my master install kit. looks like there are some pinion shims in there.
Old June 26th, 2012, 06:54 PM   #11
Spudy
Redneck Excavator
Spudy's Avatar
so just an update. after looking harder at my install kit it included bearings for the crush sleeve style or the shims style as well as shims. lol need not to freak out so bad when things dont go together as planned lol.
Page generated in 0.22493 seconds with 56 queries
