98 xj sye drive shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2012, 09:45 PM   #1
Carbon
Yooper
Carbon's Avatar
Default 98 xj sye drive shaft
Looking for a complete rear sye drive shaft for 98 xj.
Carbon is offline   Reply With Quote
Old June 23rd, 2012, 04:39 AM   #2
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
I have one from a '99 XJ (4.0L/auto) for $35.
Craig
Old June 23rd, 2012, 09:54 AM   #3
Carbon
Yooper
Carbon's Avatar
Perfect. Picture? Does it come complete? Can you check shipping to 49821
Text 9063997313
Old June 23rd, 2012, 10:06 AM   #4
1x1_Speed_Craig
Simplify...
No pic as of yet. Vehicle pics are in the part-out forum. It's as complete as any driveshaft is...not sure that I get your question.
Craig
Old June 23rd, 2012, 10:07 AM   #5
1x1_Speed_Craig
Simplify...
BTW, you can get shipping rates via UPS or USPS. I don't have time to box & get quotes without getting cash. : )
Check my iTrader feedback, BTW.
Old June 23rd, 2012, 01:04 PM   #6
1x1_Speed_Craig
Simplify...
Text 9063997313
Photo sent via text
Old June 23rd, 2012, 02:05 PM   #7
Carbon
Yooper
Carbon's Avatar
Also it's sye.
Old June 24th, 2012, 02:43 PM   #8
Carbon
Yooper
Carbon's Avatar
Anyone?
Old June 25th, 2012, 01:05 PM   #9
Carbon
Yooper
Carbon's Avatar
Where can I find one of these?
Old June 25th, 2012, 01:07 PM   #10
94cherokeemike
IT'S A XJ THING
94cherokeemike's Avatar
Use a xj front shaft in the rear
94cherokeemike is offline   Reply With Quote
Old June 25th, 2012, 10:34 PM   #11
Carbon
Yooper
Carbon's Avatar
I don't see how that will solve my issue. The part that is worn out is the nipple the spring goes into on my drive shaft and the pressed in ball cup. The boot and seal are missing. I found the replacement for the ball cup spring but not the boot and seal. Even if I found replacement parts the nipple is part of the shaft and not replaceable. Not to mention the front shaft is much smaller.
Old July 18th, 2012, 03:57 PM   #12
Carbon
Yooper
Carbon's Avatar
Still looking.
Old July 18th, 2012, 06:24 PM   #13
low900rr
low900rr's Avatar
I used a front shaft in the rear of my xj with SYE.
low900rr is offline   Reply With Quote
Old July 19th, 2012, 12:48 PM   #14
Jleach0696
Jleach0696's Avatar
i did this also. maybe you should post a picture of the shaft you have
Jleach0696 is offline   Reply With Quote
Old July 19th, 2012, 12:57 PM   #15
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
I see your issue. You haven't taken out a tape measure and found out on a XJ with an SYE there is 1/2" difference between the front and rear shafts.
Go grab a tape measure and verify that I'm never wrong then buy the complete drive shaft from Craig for $35. Otherwise I will because I need a cheap spare for my XJ with a rear with a NP231 W/SYE.
ckupq is offline   Reply With Quote
Old July 23rd, 2012, 08:00 PM   #16
Carbon
Yooper
Carbon's Avatar
The length is not the issue. I know they length is quite close (via tape measure). Its how it bolts up to the transfer case. The front uses a u-joint where as the rear uses the sye 4 bolt plate.
Old July 23rd, 2012, 08:51 PM   #17
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
http://www.dennysdriveshaft.com/p268...rear_ends.html
this may work check the measurements
Old August 1st, 2012, 06:35 AM   #18
Carbon
Yooper
Carbon's Avatar
Thats not the part thats worn out.
Page generated in 0.44831 seconds with 77 queries
