putting disc on a 9in...? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2012, 12:37 AM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default putting disc on a 9in...?
I have a 78 Ford 9in goin under my Ranger and I really dont want to use the drum brakes...Been searching but cant find any real parts list on converting to some 5x5.5 rear disc brakes.
Anybody have a receipe?
Old June 21st, 2012, 05:02 AM   #2
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
I used front rotors from a 1979 F-150 and front calipers from a 1980 Chevy K10. Speedway motors carries some brackets that you can use, but I got a set from Unlimited Offroad. I'm sure there are others out there that carry brackets.
*2007 Rubicon
*2006 Duramax
Old June 21st, 2012, 05:23 AM   #3
^^^ this
Stock Car Products also carries them.
http://www.stockcarproducts.com/rsusp4.htm
Old June 21st, 2012, 06:42 AM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Get an 80-86? 9" and explore disc bolt on minus drilling the rotor
Old June 21st, 2012, 06:48 AM   #5
diesels77
Hold on
diesels77's Avatar
Jeff's Bronco Graveyard sells the complete kit.
diesels77 is offline   Reply With Quote
Old June 21st, 2012, 11:32 AM   #6
firehawk
Live Action!
firehawk's Avatar
I think explorer rear discs work, just need to make or buy a spacer.
This is my plan once I get the bronco driveable.
Old June 21st, 2012, 01:23 PM   #7
Jeepaholic
Jeepaholic's Avatar
Yes you have to drill out the backing plate for the larger bolts and there needs to be 1/8" spacer or if you are getting new shafts order them with the correct brake offset
Old June 21st, 2012, 01:23 PM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
The front rotors and calipers ,you get for a 4wd truck?
I like those weld on brackets and may try those
Never even thought about checking with Jeff's
Old June 21st, 2012, 01:26 PM   #9
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Talk to rocksolid performance I bet they can hook you up with the brackets you need.
Old June 21st, 2012, 01:33 PM   #10
deathbypsi
Brian R.
deathbypsi's Avatar
http://broncograveyard.com/bronco/i-...1-2-studs.html
ok this seems a little much to me. 300.00 and you get no hoses,no calipers,no pads and a custom rotor they drill out so I cant just go to the parts store for a replacement?
I think I could do better than that by just buying some brackets and getting the rest at the parts store.
Old June 21st, 2012, 01:35 PM   #11
chadcooper55
Shoot beejers a pm he is the main fab guy at rocksolid. He is great to deal with.
Old June 21st, 2012, 02:33 PM   #12
firehawk
Live Action!
firehawk's Avatar
Try and get the explorer rears.
Old June 21st, 2012, 02:36 PM   #13
Somewhere in one of my build threads I had what I did all listed out. I used mid 70's chevy front calipers and 90's dodge front rotors and weld on brackets.
Old June 21st, 2012, 02:56 PM   #14
Coyote Red
Coyote Red's Avatar
Summit carries disk conversion kits.
http://www.summitracing.com/search/D.../?Ns=Price|Asc
Coyote Red is offline   Reply With Quote
Old June 21st, 2012, 03:09 PM   #15
deathbypsi
Brian R.
deathbypsi's Avatar
do you just mean the brackets and calipers? I was told you cant redrill the rotors to 5x5.5
Thats what Im talkin bout ^ I will look thru your build tonite at work when I have about 13 hours to kill. lol Its only like 372 pages now rite?
Old June 21st, 2012, 03:15 PM   #16
deerebowtie
Unchained
deerebowtie's Avatar
1 can spray paint, 2 clean used ford 5 lug rotors, 2 caliper rebuild kits, 2 used calipers, a 12$ set of brackets, speedway flex lines to a "T" AN union, some 1/4" zip ties. bam ~60$ and a few hours time.
Old June 21st, 2012, 04:09 PM   #17
These Brackets
http://www.speedwaymotors.com/1969-1...CKET,3348.html
Napa Part #'s
1975 Chevy 1/2 ton 4wd come with pads
Calipers #142-2022 and #142-2023
Parts Plus #'s
1995 Dodge 1/2 ton 4wd......because these fit over the stock flanges of the shafts with no grinding
Rotors P76447
Brake Hoses #BH36761
Little Spacers from Lowe's....cut to fit inside the rotor where the lug stud slides through to center the rotor over the studs
the spacers are "Hillman" no part number but they measure 1/2 x 5/8 x 1
found them in the little hardware isle in the chest of drawers
If I remember I had to grind the brackets a bit to fit the tubes, but for the price it wasn't a big deal, but that was like 4 yrs ago. I have done ALOT of things since then
Post was from this thread
9" disc brake parts and 44 high steer help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2012, 12:32 AM   #18
deathbypsi
Brian R.
deathbypsi's Avatar
Thanks John!
Old June 30th, 2012, 11:05 AM   #19
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I did the speewaymotors weld on brackets. I had to drill out the stud holes on the 78 f150 front rotors to fid the studs, then I run moser shafts so I had to grind down the outter flange to allow them to fit inside the rotor. Not much, just a hair.
When you go to weld them on, hook up air to the bleeder valve. This will clamp the pads to the rotor and you know its flush..
Old June 30th, 2012, 03:12 PM   #20
deathbypsi
Brian R.
deathbypsi's Avatar
Awesome! I love pix. So what app are the calipers and pads for?
Page generated in 0.33977 seconds with 84 queries
