2004 Durango 4.7 4x4 Custom Drivetrain - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2012, 10:28 PM   #21
firehawk
Live Action!
firehawk's Avatar
Originally Posted by schanxj View Post
Yikes, $3100? They sure aren't giving those things away. Seems worthwhile to look into stock replacement used low mileage first.
Used low mileage I cannot find.
I figure a reman with warranty will help with resale too.
Old April 30th, 2013, 05:00 PM   #22
GreenSound
GreenSound's Avatar
A rebuild kit isnt too terribly expensive for that engine. I have an 04' as well with the 4.7 and am sorta in the same boat... http://www.airram.com/product.php?ca...productid=1535
I bought mine with only 125 psi compression on cylinder 1 (vs. about 150 psi on the others) Bore scoped it and the cylinder wall is pretty scored.
The 4.7 can have a tendency to sludge and can lead to clogged lifters (inducing valvetrain noise!!!) They are atleast decent on fuel.
I am currenty swapping the NV144 single speed transfer case out for a BorgWarner 44-45 transfer case (2wd, 4Hi-lock, 4Lo). The front output bearing is blown out on the NV144. The 44-45 is the Part-time trasnfer case available on 2011+ Rams similar to a NV244 but with no "full time 4wd"
Anyways back to your predicament.. either rebuild the one you have, swap a used, or go hemi. Just depends on price... the hemi swap is not bad in reality. The cam and crank sensors are same pattern, so realistically you need a predator tune along with a manual cable hemi throttle body (its even designed to use the 4.7 IAC).
Mine just misses at idle a little but 10w40 with rislone "stop smoke" seems to help a lot.... you on the other hand have a broked-engine. Used hemis arent going for much more than used 4.7s on craigslist (and are seemlingly more available). But a rebuild is still cheaper...
GreenSound is offline   Reply With Quote
Page generated in 0.16930 seconds with 29 queries
