Power steering fluid? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 14th, 2012, 02:37 PM   #1
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Default Power steering fluid?
I've herd of a lot of guys running trans fluid instead of power steering fluid.
Any advantages to this? Some are stock steering and others are full hydro.
I have full hydro and I'm using standard power steering fluid. Has any one used any thing else?
I know old tractor hydraulic oil is also the same as trans fluid but its clear. Any one ever try that?
Old June 14th, 2012, 03:20 PM   #2
Bones
Bones's Avatar
GM synthetic power steering fuid, or amsoil tractor fluid are your best bets for a system with a hydro ram.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 14th, 2012, 03:34 PM   #3
redhead_823
redhead_823's Avatar
I use tractor hydraulic oil. Comes in a 5 gallon pail. Leaks out just as fast.
redhead_823 is offline   Reply With Quote
Old June 14th, 2012, 03:34 PM   #4
zoomin0074
My 2006 Dodge Ram uses ATF +4 in power steering and trans.
zoomin0074 is offline   Reply With Quote
Old June 14th, 2012, 08:32 PM   #5
Why?
Old June 14th, 2012, 08:57 PM   #6
Yota Bill
Why?
Because it costs more, that's why.
Seriously, just use what your pump used originally, since it's the only thing in the system that is really going to care.
As for using ATF instead of power steering fluid, they are essentially the same thing, but you may notice some foaming and a bit more noise with the ATF. I would go with the ATF, since it is cheaper, and works just as well.
Old June 14th, 2012, 09:00 PM   #7
buttercr125
I work out
buttercr125's Avatar
Higher boiling point and handles heat better without breaking down.
Old June 14th, 2012, 10:02 PM   #8
Bones
Bones's Avatar
Why?
Won't degrade or "burn/boil" at higher temps, won't foam, won't cavitate, which is what kills pumps
no OEM pump is made to run a hydro ram system. The systems are not even comparable
bingo
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old June 14th, 2012, 10:16 PM   #9
Yota Bill
It is a hydraulic pump. Nothing more, nothing less. It moves oil, and doesn't care what it moves that oil into.
Obviously a higher boiling point is a good quality to have, but a cooler and fan can also solve that problem, and should be used regardless.
Old June 14th, 2012, 11:01 PM   #10
RioGrande
RioGrande
RioGrande's Avatar
I have a full hydro PSC system. Their web site says in clear plain english to use plain power steering fluid and absolutely do not use trans fluid. http://www.pscmotorsports.com/Tech-Info click on bleeding instructions. There is also a huge thread discussing this on Pirate. So with that said I am currently using Pennzoil non synthetic power steering fluid. Works great so far.
RioGrande is offline   Reply With Quote
Old June 15th, 2012, 12:21 AM   #11
Coyote Red
Coyote Red's Avatar
You wheel farm equipment so it seems reasonable.
Coyote Red is offline   Reply With Quote
Old June 15th, 2012, 01:44 AM   #12
welderbrian
welderbrian's Avatar
I run mobile 424 in mine hydro assist, no problems
welderbrian is offline   Reply With Quote
Old June 15th, 2012, 05:00 AM   #13
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I did a ton of research on this subject last year - and trial by fire.
Power steering fluid dosn't foam up as quickly as tranny fluid.
Tractor style hydrolic fluid works fine for the summer months, but has a tendency to destroy the pumps when it's really cold out unless you really let things warm up well before you start winter wheeling.
FYI: You can pick up a whole gallon of Valvoline PS fluid for about $23 at most auto parts stores.
Old June 17th, 2012, 11:59 AM   #14
Jeeper52
Budget, what budget?
Jeeper52's Avatar
funny, when I was a much younger mechanic we used trans fluid for all steering. when rack and pinion came out, we needed to use ps fluid. thats just what I was told to use not sure why
Old June 17th, 2012, 12:22 PM   #15
92FleXj
92FleXj's Avatar
I used trans fluid in my first hydro set up and cooked my pump. It was foaming up a lot too.
I just re did my hole set up from start to Finnish and this time I'm running PS fluid.
Old June 17th, 2012, 01:49 PM   #16
Tab
Tab's Avatar
So you guys are using tranny fluid to save what, like three bucks? That's retarded. My full hydro system uses about three quarts with the cooler and I think the stuff I use is around five something a quart. So in order to save a couple dollars it's worth the risk to your pump? Just so I can add something useful, I use valvoline synthetic and have never had an issue or even have it get hot.
Old June 17th, 2012, 04:26 PM   #17
92FleXj
92FleXj's Avatar
I never said it was to save $
I used it because I always have trans fluid on the shelf never have PS fluid.
I was also always told they were the same.
Old June 17th, 2012, 05:43 PM   #18
I used ATF because that was what the Toyota required.
Old June 17th, 2012, 07:14 PM   #19
Tab
Tab's Avatar
Well that makes sense if that's what is recommended by what you're running. I assumed people wanted to do it to save money, I didn't realize it was because they were too lazy to buy ps fluid. It just seems too easy to just run what's recommended.
Page generated in 0.35996 seconds with 80 queries
