axle joint fazing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 13th, 2012, 09:18 PM   #1
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
Default axle joint fazing
ok i have 76 dana 44 from a waggy going in the cj i have 4.09 gears and a mini spool what phasing of the axle joints will give me the best steering with this set up perpendicular to eachother on axle sides or 90 degrees off thanks for the help
HPandThrottle is offline   Reply With Quote
Old June 13th, 2012, 09:25 PM   #2
Bo's Cj 7
Bo's Cj 7's Avatar
I don't think it matters it won't steer very good either way with a spool
Bo's Cj 7 is offline   Reply With Quote
Old June 13th, 2012, 09:34 PM   #3
HPandThrottle
i know it will be hard in the slow tight turns but i read some where once that said which way was better but it was so long ago i cannot remember how it said to phase them but it did say one way was much better just wondering if anyone else has done this and remembers which way is better is all no matter what it will be hard but i have lockouts
Old June 13th, 2012, 09:46 PM   #4
Bo's Cj 7
Bo's Cj 7's Avatar
Front Axles Installed In Phase? Question for the Mechanical Types - A Bit Long - JeepsUnlimited.com Forums
Here is one link I found
Old June 13th, 2012, 10:07 PM   #5
HPandThrottle
i have found some info int the last few that all say to keep perpendicular so i guess that is what i will do if it is too hard i will change it and try it i guess
Old June 13th, 2012, 10:10 PM   #6
Bo's Cj 7
Bo's Cj 7's Avatar
I thought if we bumped it enough someone else would responed
Old June 13th, 2012, 10:23 PM   #7
HPandThrottle
oh well time to learn by trial and error i guess
Old August 20th, 2012, 07:40 PM   #8
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
You want both inner shafts perpendicular to each other
Old August 20th, 2012, 09:30 PM   #9
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Yes, this is the easiest on joints and steering. It's an old mud boggers trick and it works, with stock shafts I would tack the joint caps as well.
Page generated in 0.18667 seconds with 51 queries
