resistors where to buy? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 12th, 2012, 09:53 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default resistors where to buy?
i'm in need of a resistor of a specific value where can i find one? 3750 ohms is the magic number i need. i looked at radio shack and their selection is pretty crummy.
Old June 12th, 2012, 10:03 PM   #2
itselliott
itselliott's Avatar
Try this:
http://www.mouser.com/
I shop it for electronics. Good service.
Old June 12th, 2012, 10:04 PM   #3
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
I bought capacitors and some stuff of the internet, to fix our Samjunk TV.
I do not remeber the specific web site, there are several out there.
Had them at the house the next day, the whole deal shipping and all was less than 10 bucks.
Supreme Chancellor!
dougstephvoor is offline   Reply With Quote
Old June 12th, 2012, 11:32 PM   #4
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I usually use jameco.com
Old June 12th, 2012, 11:34 PM   #5
dfm_13
dfm_13's Avatar
radioshack sucks, all they sell now a days is cell phone shit
dfm_13 is offline   Reply With Quote
Old June 12th, 2012, 11:43 PM   #6
brewmenn
brewmenn's Avatar
Yep, cell phones and crappy RC toys.
Old June 12th, 2012, 11:55 PM   #7
Lousypirate
Whoop Whoop
Lousypirate's Avatar
mcmaster should have some of this stuff too?
Old June 13th, 2012, 08:45 AM   #8
At work, and at home, I use digikey as my first source. Mouser and a few others if not.
3.75k is not a standard value, you will liekly not find it, even at a good supply house.
You could go with a 3.74k:
http://www.digikey.com/product-detai...FCT-ND/1555062
Or if you absolutely needed 3.75k, then you put a 10 ohm resitor in series with it.
Old June 13th, 2012, 10:09 AM   #9
JeepInABox
In too deep
JeepInABox's Avatar
Resistance is futile.
But can be bought online fairly cheap.
Old June 13th, 2012, 10:28 AM   #10
AJ Hall
Kickin' Up MUD
I think home depot has electrical things like that in the hardware section
AJ Hall is offline   Reply With Quote
Old June 13th, 2012, 09:57 PM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Electronic connection in Westland. Its located on the SE corner of Newburgh Rd. and Ford Rd. Really nice selection of all things electronics and very helpful people that know what they are talking about.
Plato2k5 is online now   Reply With Quote
Old June 14th, 2012, 09:25 PM   #12
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well thanks for all the info. turns out i don't need one after all. my camaro has the chipped key and all of a sudden it wouldn't start. looked at everything from the starter up to the ignition. thought it was the VATS module, so i was going to bypass it. looked at it again today found out it's a bad engine ground as my fans also weren't working which seemed strange as the circuits aren't tied together at all.
Old June 14th, 2012, 09:49 PM   #13
buttercr125
I work out
buttercr125's Avatar
Ok to start with why rig it and not fix it correctly? Was or is your security light coming on? Make sure it comes on with key on engine of during bulb check. Those cars are very common for the wires coming out of the ignition switch braking and causing a no start condition.
Old June 15th, 2012, 07:52 PM   #14
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
the security light was coming on and staying on, hence why i was thinking it was the vats system. now that i fixed the ground it comes on then goes out like it should. i wanted to bypass the vats system as a test to see if that was in fact the problem. i like the system but it does have it's flaws.
Page generated in 0.25291 seconds with 65 queries
