Welding Chrome Moly - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 8th, 2012, 01:30 PM   #1
SteelTherapy
SteelTherapy's Avatar
Default Welding Chrome Moly
Is it possible to use a Flux core wire feed welder to weld Chrome Moly steel to hot rolled steel? If so, anything special techniques or considerations required?
If not, what is the preferred welding technique?
Thanks in advance.
SteelTherapy is offline   Reply With Quote
Old June 8th, 2012, 02:42 PM   #2
In general yes. The big thing with Chrome moly is pre heat and post heat.
Old June 8th, 2012, 03:02 PM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Tig welding chromoly I have user er70 with no preheat. After it has cooled completely I heat to around 1200 degrees, the thicker the material the longer I keep it hot. Let it cool after that and you are good to go. If you don't normalize it after you weld it will be brittle.
Old June 11th, 2012, 04:26 AM   #4
SteelTherapy
With pre and post heat, will a MAP gas torch be good enough?
Old June 11th, 2012, 04:35 AM   #5
madscience
Ballsohardthatshitcray
madscience's Avatar
Depends on the thickness of the material being welded.
madscience is offline   Reply With Quote
Old June 11th, 2012, 06:01 AM   #6
chadcooper55
Imo no it isn't. Letting it cool completely then reheating is very important. As it cools it will have uneven stresses throughout the weld. You have to get it hot enough to relieve the stress which is around 1200 degrees. You will never get that with a map gas torch. It doesn't need to be done immediatly just before you put the weld into use. You can weld it up and bring it to someone's house that has a real torch.
Old June 11th, 2012, 06:01 AM   #7
chadcooper55
Get a 1200 degree heat stick to check it.
Old June 11th, 2012, 06:12 AM   #8
SteelTherapy
It's a spindle for a swingout tire carrier. It is 1.5" in diameter. Since this is the only chrome-moly part perhaps it would be better to just have someone weld it for me.
Old June 11th, 2012, 08:03 AM   #9
chadcooper55
If it was me I would have someone tig it. Not to say MIG won't work but tig will be better.
Page generated in 0.28586 seconds with 50 queries
