Advice on breaking in a fresh engine. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2012, 04:27 PM   #1
madscience
Ballsohardthatshitcray
madscience's Avatar
Default Advice on breaking in a fresh engine.
today i'm picking a up a rebuilt engine for my Falcon. It's never been run or started since the rebuild, and it's been sitting on the stand for a couple years. any advice or pointers for breaking in a fresh engine? what do you guys use for oil? how long till you change it? retorquing stuff later on?
btw, it's a 1969 spec 200ci Ford Thriftpower six.
madscience is offline   Reply With Quote
Old June 7th, 2012, 04:30 PM   #2
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
If its a flat tappet syle cam, Read This:
89 yj - 396 bb - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2012, 04:38 PM   #3
deerebowtie
Unchained
deerebowtie's Avatar
get the zinc additive (lucas oil or whatever you like for the flat tappit). follow the rpm run guides for cam wear break in. tempering steel (cam lobes in this case) is a proven process, don't fukc with a proven process because "you knowed better den hem". Pics of new motor?
Old June 7th, 2012, 04:41 PM   #4
Coyote Red
Coyote Red's Avatar
I would pull the valve cover and oil pan and pour break in lube (sometimes called assembly lube) on the lifters, rockers, cam, crank bearings, and piston walls. You can get break in lube and oil at Carquest and such, it should contain HIGH levels of zinc or ZDDP. If you can not get break in specific oil get any conventional or semi conventional blend, and add ZDDP yourself. Modern synthetics have been rumored to wear old style flat tappet cams excessivly due to lacking lubricity. The zinc is a high pressure lubricant that used to be in the oils when this car would have been new. I ran my break in oil for about 100 miles then changed it out.
When you do fire it let it run for ten to fifteen minutes altering the RPMs between 2000 and 3000 in steady movements (don't just blip the throttle but cycle it in that range). This is to ensure that oil is splashed and pushed around the entire rotating assembly. (This was the break in that Comp recommend when I broke in my new cam.
Coyote Red is offline   Reply With Quote
Old June 7th, 2012, 04:59 PM   #5
Outdoors
Field Repairs
Outdoors's Avatar
If it was assembled correctly with asseble lube, you will not have any prblems from it being stored on a stand for a couple of years. If I remember right, you have to prime the 200 oil pump. Before you get it in the vehicle, I would do this.
Everyone has their own beliefs on how to break in an engine. Mine is to run it a little, (not more than 50 miles), change the oil and filter, run it to 500 miles, change the oil and filter again. From there on you are golden. I have never had a problem using standard Quaker State 10-30 for this, and I run engines for a long time. BUt that's just my view...
Outdoors is offline   Reply With Quote
Old June 7th, 2012, 05:02 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
use the zddp additive and assembly lube for break in with dino oil of your choice.
after that you can look into oils that still have zddp in them.
valvoline vr1 race oil has plenty of zinc and phosphorus for cam lube.
also mobil 1 5w40 is about the highest you can find. 1200ppm zinc and phosphorus.
run it 15 to 20 mins, over 2k rpm, under 3k rpm. no idle time! no steady rpm time!
once your driving it change the oil at about 500 miles.
change it again at about 1500. then its ready to run.
good luck
Old June 7th, 2012, 05:07 PM   #7
curbdog17
Mini Van
curbdog17's Avatar
Take it to the dunes and hammer down for an hour then dive it through a water hole to cool the engine rapidly. Repeat the for an entire weekend and the motor should last you a lifetime
curbdog17 is online now   Reply With Quote
Old June 7th, 2012, 06:26 PM   #8
I suck cocks. Lots of them.
locally famous
run it how its going to be run. always worked for me. cam break-in is 20 minutes, keep an eye on gauges, and make sure the water is full without air pockets. after that i freely abuse them. hard to put 500 easy miles on race motors
Old June 7th, 2012, 09:09 PM   #9
madscience
madscience's Avatar
Just ordered tow cans of Detroit Diesel Alpine Green engine enamel (i hate the stock ford blue).
Old June 8th, 2012, 12:12 AM   #10
locally famous
unless falcons are growing in popularity in caro, im sure i have seen you around. 4 door, gray, packed with gay dudes?
Old June 8th, 2012, 05:27 AM   #11
madscience
madscience's Avatar
fordor, gold, packed with my fat ass.
However, there are four falcon owners in caro that i know of, and two of us DD our cars. so who's to say there's not a gray one out there?
Old June 8th, 2012, 07:42 AM   #12
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
It looks gray from a distance.
Old June 8th, 2012, 04:41 PM   #13
madscience
madscience's Avatar
well that must mean you look gay from a distance, because you're one of the only Dudes who rides in it with me. Come to think of it, every guy with the exception of my son that has ridden in that car with me is on GL4x4. weird.
Old June 10th, 2012, 10:30 PM   #14
madscience
madscience's Avatar
Block is now in primer, and the head has been torqued down.
Interesting note: whoever did this motor replaced the non-adjustable rockers with adjustable rockers (either aftermarket, or possibly 144 spec). Is this God's way of telling me to stab a street/strip cam into this bitch before it goes into the Dirty Bird?
Old June 10th, 2012, 10:34 PM   #15
osteologation
Old June 10th, 2012, 10:39 PM   #16
madscience
madscience's Avatar
it's late for me, i meant to say rockers.
Old June 10th, 2012, 10:50 PM   #17
osteologation
Old June 10th, 2012, 11:00 PM   #18
madscience
madscience's Avatar
if i do the 50/500/etc mile oil changes, do i add zinc each time, or just inititially?
Old June 15th, 2012, 01:26 AM   #19
Coyote Red
Coyote Red's Avatar
With flat tappet cams like, that each time. Brad Penn and Mobile VR1 come with zinc already mixed in. I run Brad Penn in my 1986 300-6 block.
Page generated in 0.35673 seconds with 81 queries
