Rear axle spline count, Ford 8:8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2012, 01:48 PM   #1
spiderman32
GETTING THERE
spiderman32's Avatar
Default Rear axle spline count, Ford 8:8
So i switched my dana 35 in the rear to a Ford 8:8, Just to get it up and running with my current drive shaft i want to switch out the u joint connector from the dana 35 to the ford 8:8. The ford 8:8 has the flat/round flange. Is it the same sline count? does anyone know if this will work or do i have to go find another u joint type, What is the spline count on this?
spiderman32 is offline   Reply With Quote
Old June 7th, 2012, 02:20 PM   #2
jonzer12
Typical way to address this is just to buy the a 1310 compainion flange. Google for the part numbers. I bought mine at napa for $24 bucks a few years ago. No reason to mess with swapping it out for a yoke.
jonzer12 is offline   Reply With Quote
Old June 7th, 2012, 02:57 PM   #3
ajmorell
ajmorell's Avatar
Even if it was the same spline count as the 35, the pinion is not the same diameter. You need to either buy this:
http://eastcoastgearsupply.com/i-498...er-flange.html
or this:
http://eastcoastgearsupply.com/i-576...bolt-yoke.html
Old June 7th, 2012, 03:39 PM   #4
spiderman32
GETTING THERE
Thanks for the help
Page generated in 0.14483 seconds with 35 queries
