1-ton YJ project part out, NE Ohio/Pittsburgh PA - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old June 5th, 2012, 04:42 PM   #1
bstewart91yj
Jeepaholic
Default 1-ton YJ project part out, NE Ohio/Pittsburgh PA
Parting out my unfinished project. I never drove this thing since I tore it down. Specs of the build: 91 YJ, 5.9L Magnum from 1999 Dakota R/T, NV4500HD, Atlas 4 speed (1:1, 2.72:1, 3.8:1, 10.34:1), full cage, lots of GenRight stuff. Email me for information on anything.
Parts are in Bridgeville, PA (15 mins south of Pittsburgh) but I live and work in Columbiana, OH (4WD Hardware) so parts can be picked up at either location.
Email is preferred and will get you an answer much quicker than a PM.
bstewart91yj@gmail.com
Willing to ship anything on your dime or deliver anything for gas money in an 8mpg truck, your choice.
I'm selling everything and will be willing to sell the entire project, if you're interested, email me.
PayPal is accepted, you cover the fees. 2.9% + $0.30 transaction fee.
For Sale:
1978/9 Sno-Fighter Dana 60 front axle (Bill of Material 610023-2)--OX Locker, 78" cable with OX shifter, 5.38's, Superior 35 spline chromoly shafts inner/outer, CTM u-joints, Warn premium hubs, Solid Axle Engineering Chevy style knuckles and outers with Chevy disc brakes, tubes welded to center section, Mad4WD reverse tie rod high steer arms for TRE's (never drilled), SealsIt outer axle seals, POR 15'd, Stage 8 locking spindle nuts, forged 1350 u-bolt style yoke, axle is set up for SOA YJ. This axle has never been on the road since built for the YJ.
1979 Ford Dana 60 rear axle (full floating) (Bill of Material 603901-1)--Moser full spool, 5.38's, Moser 35 spline shafts (spindles bored to fit), tubes welded to center section, Stage 8 locking spindle nuts, BTF antiwrap spring perches (not welded on yet), OX diff cover, BTF disc brake brackets, all new bearings and seals, forged 1350 u-bolt style yoke. This axle has never been on the road since built for the YJ.
$8000/obo for the pair of axles
Lowered! $6500/obo for the pair of axles
5.9L Magnum engine with 79k out of a 1999 Dodge Dakota R/T. New upper end gaskets, new water pump, new oil pump/pan gasket, new plugs, PowerAid spacer, brand new-never installed hot rod style wiring harness from Hotwire Auto (Squier wiring) for stand alone installation in anything, Hedman HTC TightTubes headers with Stage 8 locking header bolt kit, flywheel, Centerforce II clutch kit, Advance Adapters universal engine mount kit, brand new Powermaster XS Torque starter. SOLD
NV4500HD is SOLD
Atlas 4 speed transfer case (built after they fixed the initial issues). 1:1, 2.72:1, 3.8:1, 10.34:1, 29 spline input to be run with NV4500HD transmissions, shifter linkage kit is brand new, never installed (universal mechanical shifters for main case/cable shifter for planetary), 1350 flanges front and rear. Atlas is SOLD
AGR Rock Ram kit for 40"+ tires (bigger pump) Brand new, box was bolted onto my project frame, pump was installed on my engine but nothing else was touched, never had fluid put in. Steering is SOLD
4 Rubicon Express 1.5" SOA 6-leaf leaf spings (brand new, with bushings) Springs are SOLD
Rubicon Express boomerang shackles (a few sets) SOLD
Poison Spyder Customs full YJ roll cage, welded together--drop it in and go SOLD
GenRight boulder series stubby front bumper with grille hoop and stinger, welded together, painted silver Rustoleum Hammered SOLD
GenRight G3 high clearance YJ fenders with 4" flare and louvered side panels (cut 3.5" off hood for clearance) SOLD
GenRight mini boatside rocker guards with tubes for stretch SOLD
GenRight high clearance comp cut full corner guards with GenRight high clearance 3" comp cut flares welded on SOLD
YJ tub (no rust) comp cut in the back, CJ style tailgate, rockers bent up for GenRight boat side rocker guards SOLD
YJ frame with Rubicon Express shackle reversal front, welded on and custom stretch in the rear (~105" wheelbase) SOLD
YJ grill, some rust, no holes SOLD
YJ hood, decent shape SOLD
YJ black dash pad SOLD
BeCool aluminum radiator setup with dual SPAL 2-speed fans and 4-speed fan controller unit for YJ with Mopar or Chevy engine with recovery tank (full modular kit with upgrades) $900/obo
Skid Row YJ engine skid pan for 4.0L YJ SOLD
Throttle Down Kustoms heavy duty YJ transmission skid plate SOLD
Probably a lot more stuff, I haven't even looked at any of it for a while
Many, many more pics available
Here is a link to my webshots album:
http://rides.webshots.com/album/576203734BjrUkR
bstewart91yj is offline   Reply With Quote
Old June 6th, 2012, 06:53 AM   #2
19602
What leaf springs were you runing on the back of the frame?
How much do you want to sell it for?
19602 is offline   Reply With Quote
Old June 6th, 2012, 08:08 AM   #3
bstewart91yj
Jeepaholic
Rubicon Express 1.5" SOA springs with the frame stretched 8" and hangers moved back.
Are you talking about the whole thing or just the frame?
Old June 6th, 2012, 09:06 AM   #4
19602
Just the frame
Old June 6th, 2012, 10:15 AM   #5
snocross2xtremes
snocross2xtremes's Avatar
Sell the r/t motor - the harness and mounts?
Old June 6th, 2012, 10:53 AM   #6
bigredjeep1
WOW that YJ was sure built! How long were you getting all those parts together!
I have a 93' YJ with a 360 and Edelbrock carb on it. Would you sell the fuel injection and wiring harness for it seperate from the motor? If so how much?
thanks Troy
bigredjeep1 is offline   Reply With Quote
Old June 6th, 2012, 01:55 PM   #7
bstewart91yj
Jeepaholic
thanks Troy
Honestly, I really don't wanna separate anything for the engine. Sorry.
Old June 6th, 2012, 01:56 PM   #8
bstewart91yj
Jeepaholic
I still have the engine, harness, mounts, headers available.
PM sent
Old June 6th, 2012, 01:59 PM   #9
bstewart91yj
Jeepaholic
Just the frame
pm sent
Old June 10th, 2012, 11:29 AM   #10
bstewart91yj
Jeepaholic
bump
Old June 12th, 2012, 08:30 AM   #11
bstewart91yj
Jeepaholic
bump
Old June 15th, 2012, 08:08 AM   #12
bstewart91yj
Jeepaholic
btt
Old June 15th, 2012, 10:53 AM   #13
bstewart91yj
Jeepaholic
Axles lowered to $7k/obo
Old June 18th, 2012, 10:05 AM   #14
bstewart91yj
Jeepaholic
bump
Old June 18th, 2012, 12:40 PM   #15
bstewart91yj
Jeepaholic
engine skid pics:
Old June 22nd, 2012, 09:42 AM   #16
bstewart91yj
Jeepaholic
Any offers?
Old July 2nd, 2012, 12:38 PM   #17
bstewart91yj
Jeepaholic
back to the top...lots of stuff left
Old July 2nd, 2012, 01:20 PM   #18
dcmsu
Are the tires and wheels available? If so, what are they?
Dan
dcmsu is offline   Reply With Quote
Old July 2nd, 2012, 03:05 PM   #19
bstewart91yj
Jeepaholic
Dan
Wheels, tires, and beadlocks have been sold, sorry.
Old July 5th, 2012, 09:50 AM   #20
bstewart91yj
Jeepaholic
Lots of stuff left!
Page generated in 0.42543 seconds with 83 queries
