87' MJ 4.0/aw4/231/hp44/9" LA/SOA 35" MTs IL/WI - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2012, 10:38 AM   #1
bigredjeep1
Default 87' MJ 4.0/aw4/231/hp44/9" LA/SOA 35" MTs IL/WI
http://chicago.craigslist.org/nwc/cto/3058696326.html
1987 Jeep Comanche long bed for sale with 4.0L fuel injected 6 cylinder motor, AW4 automatic trans with overdrive, 231 command trac t-case, HP dana 44 front axle, Ford 9" rear axle with 6" lift.
1987 Jeep Comanche long bed for sale. It has a 6 inch lift using rubicon express coil with a front radius arm type suspension and bastard pack leaf springs in the rear using the mj pack with a few xj leaves. The radius arms are built using 2" x .25" square tubing and ruff stuff 1.25" hiems. All new steering linkage built with 1.5" x .25" wall DOM tubing and 3/4" and 7/8" hiem joints. Front track bar is also built with 3/4" hiems and 1.5" x .25" wall DOM tubing and ruff stuff brackets. Rear is installed using Ruff stuff spring perches and spring plates. Front axle is a 79 ford high pinion Dana 44 with 4:10 gears and brand new Warn lock out hubs and rear is a 79 ford 9 inch with 4:10 gears. I do have a set of 5:13 gears for both the front and rear axle that will go with the jeep. Jeep has a H.O. 4.0 liter straight six from a 92 cherokee running off of the factory renix fuel system. Has an AW4 trans with a NP231 transfercase. Gauges have been replaced with aftermarket Fuel level, Volt, Oil pressure, and coolant Temp gauges and has LED high beam and turn indicators. Has a small cobra CB installed. Front bumper is no longer on the jeep but I do still have the 8000 lbs electric winch that will also be included in the sale, was planning on building a stubby winch bumper for it. Has a built rear bumper with hitch reciever built into bumper with more than factory mounting tie-ins and has a flag mount that is required for most off road parks. Has almost brand new 35/12.50/15 Pro Comp MT's on a set of steel wagon spoke wheels. Jeep was used mainly as an offroad toy but can be driven to and from the trails and/or daily driven as I am now. Body is a little rough but that is to be expected with a trail rig. Unibody is solid with no cracks and door hinges have been modified for easy removal.
Asking $4,200 Located in Roscoe, IL off I-90 along IL/WI border (just south of Beloit, WI and 15 min north of Rockford, IL)
Troy 815 222 nine four 0 nine
bigredjeep1 is offline   Reply With Quote
Old June 5th, 2012, 10:08 PM   #2
01misfitcherokee
Deeper than I thought..
01misfitcherokee's Avatar
Any trades?? I have an 84 CJ7 Renegade with 4 in lift, 33'' swampers, 8,000 lbs winch, aftermarket front and rear bumpers, twin stick transfer case, b&m shifter, rebuilt dodge 360, hard top, hard doors, bikini top, soft half doors, interior in great shape. PM me.
01misfitcherokee is offline   Reply With Quote
Old June 6th, 2012, 11:33 AM   #3
mud_digger
mud_digger's Avatar
pics?
mud_digger is offline   Reply With Quote
Old June 6th, 2012, 11:39 AM   #4
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
SlayerXJ is offline   Reply With Quote
Old June 8th, 2012, 03:30 PM   #5
bigredjeep1
I pirated the steering off of it and put on some worn 33x12.50x15 SS Truxus tires on nice black rims steel rims. Current steering is a stock HP44 setup from F150.
$3800 OBO
I could use the $ and have 6 Jeeps currently so I should thin out the herd but I will entertain trades, even stockers. (XJs 97-01', TJs 97+, ZJs 96-98, etc).
Old June 11th, 2012, 09:14 AM   #6
bigredjeep1
$3500 OBO
Now has worn 33" SS Truxus MTs, stock steering, no rear bumper, but has a double tube front bumper.
text me at 815 222 nine four 0 nine and/or troystein@gmail.com for more info and pics thanks Troy
Old June 13th, 2012, 01:16 PM   #7
bigredjeep1
$2500 OBO
Old June 15th, 2012, 10:04 AM   #8
bigredjeep1
Updated pics and info:
http://chicago.craigslist.org/nwc/cto/3075060149.html
6" RE express coil with a front radius arm type suspension and bastard pack leaf springs in the rear using the mj pack with a few xj leaves. The radius arms are built using 2" x .25" square tubing and ruff stuff 1.25" hiems.
Asking $2,800
Old July 2nd, 2012, 01:58 PM   #9
bigredjeep1
$2700 OBO 35" PC MTs back on with lil mileage on them.
Old July 5th, 2012, 12:57 PM   #10
bigredjeep1
$2600 FIRM with good 35" PC MTs, $2000 with roller tires/rims.
http://chicago.craigslist.org/nwc/cto/3116787574.html
Added a front double tube bumper and pirated the rear bumper for my other MJ.
Old July 12th, 2012, 11:32 AM   #11
bigredjeep1
ttt
Trades?
Page generated in 0.23285 seconds with 56 queries
