17" LCD Monitor $25 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2012, 08:35 AM   #1
cornrowcornilius
Default 17" LCD Monitor $25
I got a new 22" monitor and dont need this one anymore, it works 100% and looks like new. It is a KDS USA K-715S and located in Three Rivers; the spec are as follows:
K715s
17" Ultra-Thin LCD Display
The K717s and K715s 17” LCD displays are an excellent choice for replacing your conventional CRT monitor. LCD flat panel technology takes up less space, and uses less power than conventional CRT monitors. These units are housed in a thin profile frame and will display a maximum resolution of 1280 x 1024. Key features include an integrated power supply (no power brick), PC and MAC compatible, and is wall mountable.
General Description
Panel Size (in.) 17"
Display Area (Landscape HxV) (in.) 13.3"x10.6"
Pixel Pitch 0.264mm
Brightness (cd/m˛) 260nits
Contrast Ratio 450:1
Video Response 16ms
Horizontal Viewing Angle 140°
Vertical Viewing Angle 140°
Optimum Resolution 1280x1024
Display Colors 16.2M
Horizontal Freq. 31 - 80kHz
Vertical Freq. 60 - 75Hz
Bandwidth 135MHz
Compatibility PC, MAC
Interface Analog D-Sub
Power
Power Supply Integrated
Standby Consumption <3W
Maximum Consumption 40W
Dimension / Weight
Physical Dimensions (WxDxH) 14.9"x7.5"x14.9"
Packaging (WxDxH) 17.1"x5.5"x19.5"
Net/Gross Weight 8.4lbs. / 9.9lbs.
Features
Plug & Play Yes
Auto Adjustment Yes
Integrated Speakers No
Control Buttons 4 keys
Tilt Angle (degrees) +30° / -5°
Kensington® Lock Port Yes
VESA® Wall Mount Option Yes
Regulations
CE, FCC DOC, CCC, CB, UL/CUL, TUV/GS, BSMI, S-Mac
cornrowcornilius is offline   Reply With Quote
Old June 4th, 2012, 09:57 AM   #2
cornrowcornilius
Ttt
Old June 5th, 2012, 01:27 PM   #3
cornrowcornilius
$25?
Old June 8th, 2012, 07:48 AM   #4
cornrowcornilius
Up
Old June 9th, 2012, 08:02 AM   #5
cornrowcornilius
up
Page generated in 0.17904 seconds with 38 queries
