machining h2 rims - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2012, 07:45 AM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default machining h2 rims
In another post someone said that you could machine the hub hole on an h2
rim to fit 14 bolt and d60 with a dremel type tool. Does anyone know how
much needs to be removed. I'm kinda leary about this. If it is a few thou I
think it would be alright but if its more I'ld rather
have it done properly. is there someone willing to machine them for me. I am
about to pick up the rims today or tomorrow.
Mike
Old June 1st, 2012, 08:16 PM   #2
Jeeper52
Jeeper52's Avatar
ttt
Old June 6th, 2012, 02:41 PM   #3
Jeeper52
Jeeper52's Avatar
surely someone could use some extra cash. I dont mind paying, just not being raped
Old June 9th, 2012, 11:53 AM   #4
Jeeper52
Jeeper52's Avatar
ttt
Old June 9th, 2012, 12:10 PM   #5
boggin-machine
boggin-machine's Avatar
just take a dremel and clearance them as needed. after you do one take a measurement on whats needed and then you can do the same on the others.
if you had to do this on several rims i would take a peice of steel and and put one hole on each end 6.5 inchs on center apart from one another and bolt it to the rims. find center and punch a hole. take the correct size hole saw and drill it out. once you do it on one rim the rest will be marked correctly.
Old June 9th, 2012, 12:26 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
the rims are not hub centric. the hub hole is not super critical. if its off a hair, but fits over the hub, only you will know.
anyone make a hole saw that size? that seems like the easy way?
joe_jeep is online now   Reply With Quote
Old June 9th, 2012, 12:39 PM   #7
boggin-machine
ya they make some pretty big hole saws. up to like 6 or 7 inchs ive seen.
Old June 9th, 2012, 02:14 PM   #8
Tom
Because racecar
Tom's Avatar
Many people use a router and a cheap trim bit. Dar did on here did it that way. Takes less than 5 min for each wheel. You can read more about it here:
http://www.dieseltruckresource.com/d...d-t193184.html
Old June 9th, 2012, 09:45 PM   #9
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
It is simple and it doesn't take long as previously mentioned. You don't have to worry about throwing the rim out of balance since it is so close to the center. A burr bit on a dremel or in a drill is easy. A hole saw would be a pita since you only need to open them up a pinch. Measure the hole in your rim and the hub on your axle, I bet it is no more than an 1/8" difference. Just use lots of wd40 or you will gum your bit up so fast it will be junk after one rim. Just keep going round in circles inside the rim til it fits. Or spend 10 times as much money and have them machined and you will end up with the same thing.
Old June 9th, 2012, 10:32 PM   #10
itselliott
itselliott's Avatar
I have done H2 rims. Both for myself and another GL member.
Anyone with a bridgeport (or like) mill, can bore the center hole out.
It takes about 5 minutes per rim.
http://s1116.photobucket.com/albums/...t=DSCN1754.mp4
On the other hand,.....it CAN be done with a chisel and hammer also .
Old June 9th, 2012, 11:14 PM   #11
XXXJ
Desert Rat
XXXJ's Avatar
I had mine machined.
It was worth it having them done right, I recapped my investment when I sold them.
Old June 10th, 2012, 07:40 PM   #12
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Anyone with a bridgeport (or like) mill can bore the center hole out.
itselliott machined the H2s on my LJ, and I couldn't be happier with the work.
I'm with XXXJ. Anything dremel-related ends up looking hacked, IMO. I looked at some H2 wheels previously (owned by someone on this forum) that were supposedly "machined". They definitely were a dremel job, and it showed.
In my opinion, it's worth doing it right and having it machined. Just my $0.02.
Craig
Old June 11th, 2012, 12:03 AM   #13
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
No need to pay someone and not hack either...
http://www.ford-trucks.com/forums/95...s-of-pics.html
Old June 11th, 2012, 10:46 AM   #14
XXXJ
Desert Rat
XXXJ's Avatar
"I cut that hole three times and it's still to big"
Old June 11th, 2012, 10:57 AM   #15
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Did you even read the link? There is a bearing that the router rides on, making it impossible to cut too deep. The bearing also guarantees that your hole will be perfectly round because it follows the same path as the factory hub hole.
Page generated in 0.36698 seconds with 68 queries
