machining h2 rims - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2012, 03:42 PM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default machining h2 rims
I am making a deal on some h2 rims. Ive heard that they will not fit 1tons hubs.s it better to machine the rims or the hubs. The main reason Im thinking to machine the hubs is for quick wheel replacement in case of trail damage. What thinks you'all
Old May 29th, 2012, 03:54 PM   #2
boggin-machine
boggin-machine's Avatar
everyone does the rims, machine all 5
Old May 29th, 2012, 03:57 PM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
The old set I had I just took a burr bit on a dremel and opened the hole up on the rim a pinch. The set i have now the previous owner had machined. You don't need to take much off them to make them fit. I would machine all your rims and you shouldn't have to worry about it. Then your spare will fit.
Old May 30th, 2012, 05:18 AM   #4
Jeeper52
Jeeper52's Avatar
Thanks
Old May 30th, 2012, 04:30 PM   #5
chadcooper55
If you decide to do it yourself make sure to use lots of wd40 on your bit. It helps to keep the bit from getting clogged with aluminum.
Page generated in 0.28796 seconds with 38 queries
