Boat Forums? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2012, 11:38 AM   #1
SULLY313
Default Boat Forums?
I haven't found any good local, national or global forums. Where are they all hiding?
I just picked up my first boat yesterday. 19.5' Renken 2052 Cuddy with a 305 Merc. While I'm comfortable with working on the 305, I could use a good source of information for everything else.
SULLY313 is offline   Reply With Quote
Old May 29th, 2012, 11:48 AM   #2
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
there isn't much to anything else...if you have questions ask on here, plenty of boat guys here willing to help
Old May 29th, 2012, 12:05 PM   #3
XXXJ
Desert Rat
XXXJ's Avatar
er, uh, I don't mean ot go off topic, but that is an interestion hull/cabin/deck. Can you post some more pics of the back?
Old May 29th, 2012, 12:26 PM   #4
SULLY313
No, Thats all I have. It was kind of a spur of the moment thing.
This is the same kind/size though. The cuddy is a little small but it fits the GF and I just fine enough. :)
http://www.yachtworld.com/core/listi...3261&noOfPic=2
Old May 29th, 2012, 12:46 PM   #5
SULLY313
Power steering pump leaks so I was trying to cross reference to an automotive pump. They're pretty much the same but the difference I see is the return line location to the resevoir. Saginaw pumps came with a number of return line config's from what I can see. I know I will have to swap the spring, valve and high pressure fitting from my old pump to retain the same line pressure. I thought it was leaking from the bottom of the pinch weld of the resevoir but looking at it closer, that may not be the case. So, I want to replace the whole asy.
$400 for a Mercruiser pump is ridiculous.
PO's quick fix. Missed a spot though.
The power steering return line from the "Rack" (not sure of the boat term) to the cooler so I'm wondering what the cheapest fix is for this. Its leaking right at the rubber hose as it goes into the fitting to the "Rack". Would I be ok if I just cut the hose, cut the compression joint off the fitting and clamp it? I'm assuming there isn't alot of pressure on the return line if its anything like a car.
$200 for a Mercruiser hose is ridiculous.
Old May 29th, 2012, 01:12 PM   #6
atvextreme
atvextreme's Avatar
might help for the power steering search http://www.alangrovecomponents.com/i...s/pspsheet.pdf
also LSCN.net is for st. clair stuff, but they and iboats have a tech area also
I think you may be stuck on the hose or have one custom made.
atvextreme is offline   Reply With Quote
Old May 29th, 2012, 02:35 PM   #7
SULLY313
thanks. That doc is exactly what I'm looking for.
I'll check out LCSN. I don't like how iboats doesn't have a FS section. I feel like they're forcing you to buy stuff from them. Perhaps I over looked it.
Is that return hose pressurized? I don't see why I couldn't cut the compression fitting and clamp the hose onto the remainder of the fitting.
Old May 29th, 2012, 02:44 PM   #8
rideraa
rideraa's Avatar
iboats not to bad
rideraa is offline   Reply With Quote
Old May 29th, 2012, 03:47 PM   #9
Jeep ZJ
Jeep ZJ's Avatar
Gunna call me back about that lift? Haha and x2 on iboat good place for boat info.
Old May 29th, 2012, 04:01 PM   #10
wilsonjeepers85
wilsonjeepers85's Avatar
Looks like a gm power steering pump or like old AMC I have one identical on my yj
wilsonjeepers85 is offline   Reply With Quote
Old May 29th, 2012, 04:09 PM   #11
HVYRTFT
Reed my teef
HVYRTFT's Avatar
that's because it is.
Old May 29th, 2012, 04:26 PM   #12
montecarlo33
The Violator
montecarlo33's Avatar
x2 a one off a 305/350 should work. I would take that into a parts store and compare one side by side.
Old May 29th, 2012, 04:37 PM   #13
wilsonjeepers85
You could have custom hoses made cheap there is a place by me that makes rubber hoses dirt cheap
Old May 29th, 2012, 05:31 PM   #14
SULLY313
Got one off a 94 camaro in the junk yard. $40 is much better than $400
Old May 29th, 2012, 05:40 PM   #15
SULLY313
See the thread. Updated again.
Suspension Part(s): $400 88-98 K1500 6" Lift Kit 3.73 gears and axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2012, 02:41 PM   #16
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
another vote for iboat. They have helped me out when I bought my first boat and needed to do a bellows/shift cable/trim switch job
TJJEEP is offline   Reply With Quote
Old July 9th, 2012, 12:37 PM   #17
2000_WJ
2000_WJ's Avatar
this thread is a few months old but.. I have a powersteering pump, pump cooler and hydraulic lines for sale if you still need these. They are from a 91 Thompson Calae 4.3L
2000_WJ is offline   Reply With Quote
Old August 3rd, 2012, 07:35 PM   #18
sabastian
junk yard for all 262 305 350 400 parts. it's a gm motor with all the same crap that gm used. really cheap. go to the pull your self yards and see them for your self. i also like iboats as well.
sabastian is offline   Reply With Quote
Page generated in 0.30104 seconds with 78 queries
