mercruiser 3.0 - water in oil - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2012, 10:17 AM   #1
jeeperstrudie
AdvoCare Distributor
jeeperstrudie's Avatar
Send a message via Yahoo to jeeperstrudie
Default mercruiser 3.0 - water in oil
Ok, I have a late 80's 3.0 mercruiser.
It starts and runs fine (but overheats after a couple of minutes), question i Have since it runs fine just overheats is it a blown head gasket? or more like a cracked block?
opinions?
jeeperstrudie is offline   Reply With Quote
Old May 29th, 2012, 10:49 AM   #2
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
could be either
Old May 29th, 2012, 11:00 AM   #3
jeeperstrudie
Is there a good way of testing this before I tear it all apart? if it's a blown head gasket I'll fix, if its a cracked block i'll part it out
Thanks
Old May 29th, 2012, 11:09 AM   #4
Christmas Cookie
do a leak down test
Old May 31st, 2012, 01:42 PM   #5
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
Once you get that figured out I would take a look at the impeller to see how bad it is.
TJJEEP is offline   Reply With Quote
Old May 31st, 2012, 01:49 PM   #6
jeeperstrudie
the water pump impeller is brand new, i've rebuilt the hole pump. thanks.
Old May 31st, 2012, 01:50 PM   #7
jeeperstrudie
oh, also....
I did find water in my oil pan, nothing in the cylinders but the oil has water in it. so does that conclude 100% that it has a cracked block?
Again, it runs fine other than it overheats
Old May 31st, 2012, 02:06 PM   #8
TJJEEP
TJJEEP's Avatar
No, it's not 100%. It could still be a head or head gasket problem. I'm not sure how you would test for it though.
Old June 1st, 2012, 09:48 PM   #9
jeeperstrudie
Got a new gasket set today for everything, hoping the weather holds out so I can do some work on it...
Page generated in 0.18762 seconds with 50 queries
