Jay's Ford F-350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 27th, 2012, 01:35 PM   #1
buttercr125
I work out
buttercr125's Avatar
Default Jay's Ford F-350
I decided to start a build thread for a truck that I had a hand in building. I want to start by saying this is not my truck even though I wish it was. It was a real good friend of mines truck that passed away in June of 2008. His name is Jason Amy and his dad Dave Amy now owns the truck.
Below is a couple pictures of what we started with. Its a 2000 Ford F-350 with a 7.3l Powerstroke in it. As you can see from the pictures or if you knew Jason, he took very good care of it and kept it VERY clean. It already had a 4" Rancho lift kit on it with 35" BFG All Terrains or Mud Terrains on it(switched them for summer and winter). He always talked about changing the lift and doing some other work to it and well his dad and a couple other friends have helped make it come true.
What Dave decided to do was install a 8" Full Traction ICG kit with King Shocks all the way around including the steering stabilizer. He decided on a 38" tall tire and went with a set of Toyo Open Country MT's on a set of 20" Moto Metal 959 wheels. The lift kit is currently installed and we are doing some other work to it so I will be adding pictures the next couple days to get this thread up to where we are currently at and what we will be doing to it.
A couple people from the board here have had a hand in the work that we have done to this so far. The person who has done a majority of the work so far has been CHFORD (Dustin Pitman). He is the one who did all the dis-assembly of it. sslugnuts (James Quazarano) is the other member on here who has also gave a helping hand on this.
Here is the picture of what the truck looked like before we started.
[IMG] IMG_20120322_202318 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:37 PM   #2
buttercr125
I work out
Here is the beginning of the tear down.
[IMG] IMG_20110417_140056 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:44 PM   #3
buttercr125
I work out
Here is the axles removed and ready for the fun to begin.
[IMG] 2012-04-21_18-41-23_209 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:48 PM   #4
buttercr125
I work out
We sent the axles out to be sand blasted and painted before we reinstalled them or the lift kit. While everything was removed we had the framed cleaned up and painted mainly around the wheel wells. When winter rolls around the box and possibly the cab is going to come off so we can clean the entire frame and paint it.
Here are pics of the frame areas the was cleaned and painted. Didn't turn out too bad.
[IMG] 2012-05-20_14-55-34_924 by buttercr125, on Flickr[/IMG]
[IMG] 2012-05-20_14-55-50_306 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:50 PM   #5
buttercr125
I work out
Here is a picture of a lot of parts and some pure sexxyness!!!
[IMG] 2012-05-15_19-43-24_468 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:51 PM   #6
buttercr125
I work out
Here is the axle back from sandblasting. They will primed and painted satin black next.
[IMG] 2012-05-11_21-18-58_804 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:53 PM   #7
buttercr125
I work out
Here is the rear axle all painted up and looking good.
[IMG] 2012-05-15_19-44-01_94 by buttercr125, on Flickr[/IMG]
Here is the front also ready for reassembly to begin.
[IMG] 2012-05-15_19-43-50_165 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:56 PM   #8
buttercr125
I work out
Here is the front shock hoops bolted in place.
[IMG] 2012-05-21_21-01-44_90 by buttercr125, on Flickr[/IMG]
Here is the front link mount bolted up and ready to go. As you can see in the picture the rest of the frame is still nasty and needs to be cleaned and painted which is next winters project.
[IMG] 2012-05-21_21-01-59_952 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 01:57 PM   #9
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I didn't know Jason was building that
H.o.r.e
Old May 27th, 2012, 01:59 PM   #10
buttercr125
I work out
Here is the axle bolted up and ready for some coilovers to go into place.
[IMG] 2012-05-22_20-24-49_64 by buttercr125, on Flickr[/IMG]
[IMG] 2012-05-22_20-24-35_576 by buttercr125, on Flickr[/IMG]
Rear axle hanging in place with the shocks going in.
[IMG] 2012-05-22_21-28-58_256 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 02:00 PM   #11
buttercr125
I work out
He didn't or wasn't. He always talked about changing the lift to something a little bit bigger than it was. His dad Dave and a couple people that work for him are doing it.
Old May 27th, 2012, 02:02 PM   #12
buttercr125
I work out
Front end just about done.
[IMG] 2012-05-24_22-03-14_727 by buttercr125, on Flickr[/IMG]
Some bling bling with a little rubber around it.
[IMG] 2012-05-24_22-03-40_516 by buttercr125, on Flickr[/IMG]
Old May 27th, 2012, 10:47 PM   #13
buttercr125
I work out
Here it is at its current state. We still have a lot of little things to do to it. Tonight we worked on installing a set of Amp Research power steps on it. They are mounted up but not wired yet.
[IMG] Untitled by buttercr125, on Flickr[/IMG]
Old May 28th, 2012, 09:28 PM   #14
CHFORD
CHFORD's Avatar
Hey i got some more pics of it today it looks good i like the power steps.
ID:	92950   Click image for larger version
CHFORD is offline   Reply With Quote
Old August 10th, 2012, 08:30 PM   #15
buttercr125
I work out
SAM_0874 by buttercr125
SAM_0873 by buttercr125
SAM_0871 by buttercr125
Old August 10th, 2012, 09:03 PM   #16
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Wow looks great!!!
Page generated in 0.38645 seconds with 72 queries
