Leaky TJ Dana 30 (seals or u-joint?) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 23rd, 2012, 10:50 AM   #1
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
Default Leaky TJ Dana 30 (seals or u-joint?)
Passenger side just started leaking about the same time the u-joint started clicking.
Doing u-joints tonight, my question is:
Would the extra wobble caused by a shitty u-joint allow the diff fluid to seep by the inner seal?
If i do the joints, that's 1/2 way to doing the seals, so i may as well do it all, figured I'd ask 1st tho.
And does someone have the part #'s for the inner seals? I think the YJ took different ones on either side, is a TJ the same part for both?
also, the old hubs were trashed, i replaced those months ago, i suppose that could of helped kill the seal.
Thanks
SlayerXJ is offline   Reply With Quote
Old May 23rd, 2012, 11:11 AM   #2
kmanxj5011
kmanxj5011's Avatar
Yes, I just did the same thing. You have to pull both shafts and carrier to get inner seals out. Make sure if there is shims in there you keep them in the right place and also keep the caps on the same side and aligned the same. Change both seals.
Check NAXJA for a write up on it.
kmanxj5011 is offline   Reply With Quote
Old May 23rd, 2012, 11:24 AM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
A bad axle joint killed my passenger side seal on my yj. My seal is located in the disconnect, about 15 inches from the joint though.
Old May 23rd, 2012, 11:36 AM   #4
Complete Off Road
Complete Off Road's Avatar
TJ D30 inner axle seal is a NS 710068, or Yukon p/n YMS710068.
Yes, it is different than YJ inner axle seals.
Complete Off Road is offline   Reply With Quote
Old May 23rd, 2012, 03:55 PM   #5
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
Thanks for the info and part #'s
I'm just gonna do it all while it's apart.
Old May 24th, 2012, 08:02 AM   #6
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
advanced should have the axle seals (timken brand) for $10. idk if the price is good or bad, but in stock parts are always better than ordering IMO.
i dont think autozone carries them.
napa does i would put money on, but cant say for sure.
VAhasnoWAVES is offline   Reply With Quote
Old May 24th, 2012, 01:05 PM   #7
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
I went with the Nationals from down the road.
Would have liked the Yukons, but time is a factor.
Got all of the new parts in, just need to button it back up.
edit: done. no clicks and no leaks (yet)
Page generated in 0.23843 seconds with 44 queries
