**FOUND*** Jeep TJ or XJ axles with 4.56s, maybe 4.10s.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 23rd, 2012, 08:55 AM   #1
Default **FOUND*** Jeep TJ or XJ axles with 4.56s, maybe 4.10s..
Just checking the off chance if someone had a set of Jeep axles with 4.56s already installed.
No Dana 35 rears though, would need a Dana 44, 8.8, or 29 spline 8.25.
I might consider 4.10s, but 4.56s are preferred.
EDIT: FOUND A SET OF AXLES, THANKS!
Haggar is offline
Old May 23rd, 2012, 09:01 AM   #2
bhunt
BigBri
bhunt's Avatar
I have these, they are $6300 and I throw in the TJ with them.
97 TJ Lifted, 33" Tires, $6300 - Great Lakes 4x4. The largest offroad forum in the Midwest
bhunt is offline
Old May 23rd, 2012, 12:27 PM   #3
I have plenty of Jeeps. Just need axles, thanks.
Honestly, I have a HP dana 30, and uninstalled 4.56s, and then I have a Ford 9" center chunk with 4.56s and a tru track, and sevreal housings that I can narrow. But I'm lazy and wouldn't mind finding a set already put together. And a TJ D44 or 8.8 is 50 lbs or so lighter than my Ford 9". Weight matters on this (street/sand jeep).
Haggar is offline
Old September 14th, 2012, 03:06 PM   #4
bump
Haggar is offline
Old September 25th, 2012, 07:18 PM   #5
boggin-machine
boggin-machine's Avatar
i got stock tj 410 axles. spair shafts front and rear with a few spair wheel bearings
boggin-machine is offline
Old October 3rd, 2012, 01:14 PM   #6
SteelTherapy
SteelTherapy's Avatar
I have the D44 axles from my grand wagoneer. Front and Rear are 4.56 yukon gears with, eaton e-lockers and ARB diff covers. Front has yukon chrome-moly shafts with yukon "super" u-joints, disk brakes. Rear has drum brakes. 6 - 5.5 bolt pattern. Set up for leaf springs. $1,500 for the pair.
SteelTherapy is offline
Old October 3rd, 2012, 10:15 PM   #7
Wramblerguy
Wramblerguy's Avatar
Complete Axle(s): dana 44, 4.30 gears, disc brakes $250 - Great Lakes 4x4. The largest offroad forum in the Midwest
3rd generation jeeper
Wramblerguy is offline
Old October 4th, 2012, 01:38 PM   #8
bbaXJ
Yooper In Training
bbaXJ's Avatar
I've got a super clean 4.10 geared 8.8 with limited slip and a box full of heavy duty brackets for a TJ. Shoot me a PM if you're interested.
bbaXJ is offline
Old October 7th, 2012, 05:43 PM   #9
Found what I needed :-)
Haggar is offline
Page generated in 0.27044 seconds with 51 queries
