dana30 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2012, 09:57 AM   #1
Carbon
Yooper
Carbon's Avatar
Default dana30 help
Pulled my d30 out of my 98 xj. Installing a d30 from an older xj that has vacuume disconnect. Can I just by pass and block off the disconnect?
What can I do to make this work?
What gears came in the d30 for a i6 5speed? Can I use the carrier from that for my 4.56 ring and pinion?
Carbon is offline   Reply With Quote
Old May 22nd, 2012, 10:00 AM   #2
ajmorell
ajmorell's Avatar
You need the one piece axle shaft and then to block off the CAD. If the gears on the carrier are 3.73 or higher numerically you can use it for 4.56s
Old May 22nd, 2012, 10:03 AM   #3
Complete Off Road
Complete Off Road's Avatar
yep, you'll need a long side inner and then one of these:
http://completeoffroad.com/i-123369-...39147-kit.html
Complete Off Road is offline   Reply With Quote
Old May 22nd, 2012, 01:14 PM   #4
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
I know on my vacuum disconnect on my YJ, I slid the collar over, put a hose clamp on it, plugged the vacuum ports, and called it a day. Never have an issue with it.
Old May 22nd, 2012, 01:24 PM   #5
jonzer12
Yes but you are stilling 2 peice shafts. He will need a seal kit for his 1 peice shafts.
jonzer12 is offline   Reply With Quote
Old May 22nd, 2012, 01:35 PM   #6
4x4 jeep
2 tracken in the mud
4x4 jeep's Avatar
Ran a one piece axle on passenger side on yj and only put a inner seal in the axle tube. Never had a problem and no seal kit.
4x4 jeep is offline   Reply With Quote
Old May 22nd, 2012, 01:38 PM   #7
Carbon
Yooper
Carbon's Avatar
I have both sets of shafts. What shafts should I use?
Old May 22nd, 2012, 04:44 PM   #8
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I would use one piece shafts with the larger u-joint, much stronger. Check out jeep faqs there is a write up with all info needed and part #s for seals.
Old May 22nd, 2012, 08:19 PM   #9
Carbon
Yooper
Carbon's Avatar
Ok thanks. I think I'm going to use my old axle pending inspection. If the pinion bearing opening isn't trashed ill fix the top of the case where the pinion gear hit. Little heat and a quick weld job I think ill be in business. Ordered new ring and pinion, all the u joints, brakes, bearings and what not. Should be good to go.
Page generated in 0.26280 seconds with 50 queries
