Electric Water Pump - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2012, 08:47 AM   #1
chuck202003
chuck202003's Avatar
Default Electric Water Pump
This past weekend at the mud run I had a bad over heating issue. (First run with new truck) I was thinking on getting a electric water pump. I have a 460. Any suggestions on which pump I should buy. I do not want to spend a lot of cash for one. I've found a pro comp one for $119.99 It any good?
chuck202003 is offline   Reply With Quote
Old May 21st, 2012, 09:18 AM   #2
pitbull2332
pitbull2332's Avatar
It all goes back to you get what you pay for. I had one in my sand dragster for about 2 seasons. The houseing cracked where the lower radiator hose hook up. I went to weld it up and it was full of porisity. Was a bad casting. I now have a moroso electric pump and have not had a problem. Moral, if you buy junk you are out that money plus the money to do it right. Just buy good parts from the start it will save you frustration in the long run
pitbull2332 is offline   Reply With Quote
Old May 21st, 2012, 09:56 AM   #3
Elvis13
What makes you think that the water pump is the problem?
Old May 21st, 2012, 10:37 AM   #4
cerial
Direct Drive FTW
cerial's Avatar
For the price of the electric water pump and the new belt and possible bracket/idler to make it all work your better off going with a high quality belt driven pump price wise.
I don't remember there being to many quality "cheap" parts on the last 460 I owned. It is a big block after all.
Old May 21st, 2012, 10:58 AM   #5
chuck202003
I was going to go with the electric water pump so it could circulate water through my motor with out the motor running and causing more heat. Plus it is lighter and no drag on the motor at high RPM's.
Old May 21st, 2012, 01:04 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I have hot issues with my jeep at silver lake. Come to find out my water pump is made for either drag racing, or circle track racing with aluminium heads...
So seems to me its made to spin at 5500rpm plus for the entire time. So I'm going to swap it out for a stock no hiperformance pump.
Page generated in 0.20973 seconds with 41 queries
