what would you do - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2012, 05:10 PM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default what would you do
I have a d60hp from a 79 f350 and there is a web right where the u bolt needs to go should i just grind a place for it . I cant imagine what ford did originally
Old May 20th, 2012, 06:33 PM   #2
Jeeper52
Jeeper52's Avatar
ttt
Old May 20th, 2012, 06:52 PM   #3
Tab
Tab's Avatar
I don't see why a simple notch to hold the u bolt in place would hurt anything.
Old May 20th, 2012, 07:04 PM   #4
steveo
In the band!
Cut it.
Old May 20th, 2012, 07:25 PM   #5
Ebs
Ford used a bottom plate that was notched for the webbing and square u-bolts.
Old May 20th, 2012, 07:42 PM   #6
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I drilled a hole thru mine. Grinding would work too. If you cut it deep the web will lose its strength.
Old May 20th, 2012, 07:54 PM   #7
joe_jeep
welfare wheeler
joe_jeep's Avatar
just notch it where the bolt will sit. dont go any deeper than needed.
Old May 21st, 2012, 10:54 AM   #8
treky67
millwright/jeepwright
treky67's Avatar
X2 on drilling a hole to feed the u bolt through.
treky67 is offline   Reply With Quote
Page generated in 0.73456 seconds with 47 queries
