Narrow vs wide - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 19th, 2012, 09:32 PM   #1
Wrench In Hand
Default Narrow vs wide
Starting mods on 1980 CJ7, looking to swap a narrow AMC 20 for a wide AMC 20, anyone tackle this, Direct swap? found info on shocks not bolting up not much more.
Wrench In Hand is offline   Reply With Quote
Old June 7th, 2012, 04:20 PM   #2
Wramblerguy
Wramblerguy's Avatar
Should bolt right up
Old June 7th, 2012, 04:43 PM   #3
hardwateraddict
hardwateraddict's Avatar
Yep!
hardwateraddict is offline   Reply With Quote
Old June 7th, 2012, 05:52 PM   #4
Axles will bolt in place. You might or might now have your shocks work out. They moved the shock mounts from the axle tubes to the spring plate. You could swap to the later spring plates and just not use the lower mounts on the narrow axles, if thats how yours are set up.
The drag link and tie rod need to match the wider axle.
Old June 12th, 2012, 10:30 PM   #5
Wrench In Hand
Thanks for the feed back
Old June 13th, 2012, 05:33 AM   #6
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
One more note on the front shock mounts. Yours are short, and welded to the frame. Later-model ones are tall, and bolted to the frame. Just make sure you sync the upper & lower shock mount designs so you have enough travel.
Page generated in 0.21483 seconds with 41 queries
