Project Schizo!!! - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 17th, 2007, 11:47 PM   #41
guest
Send a message via AIM to guest
NIce Phone
Git Er Done
guest is offline   Reply With Quote
Old December 18th, 2007, 09:47 AM   #42
liv2mx
i like jungle gym's.
liv2mx's Avatar
damn skooter that is some nice parts...good luck w the build.you have a ton of work to do.
Old December 19th, 2007, 12:30 AM   #43
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Today was a good day. I finished cutting off all the front end frame suspension, grinding enerything smooth. I made up a template of what i want the front tube fenders to look like, they will go into the hood and have a storage space built into them. I also mocked up 1 of the speed blisters for the hood so i can run the coilover hoops up higher through the hood to keep the Jeep as low as i can and put the front 60 under it. It will most likely stay in that position once everything is welded. Also i put on 1 of the comp corners to get a look at it. Any one know what size lug nuts go on a front kingpin 60, the ones i got the the 14 bolt are too big.
Tomorrow ill clean up the axles, removing what ever i wont be needing. Then ill tack the brackets together, and put the 14 bolt in the back. Then if im feeling froggy enough ill cut off the lower frame control brackets and then cut off the back frame, about a foot after the lower frame brackets.
I'm the man in White.
Old December 19th, 2007, 05:35 AM   #44
groundhog
groundhog's Avatar
Looken good Skooter_Built
groundhog is offline   Reply With Quote
Old December 19th, 2007, 06:10 AM   #45
Graz Man
Graz Man's Avatar
looking pretty sweat.
Graz Man is offline   Reply With Quote
Old December 19th, 2007, 06:33 AM   #46
mrclean
Silver Lake
mrclean's Avatar
Can you please get a better camera? :tonka:
Looks good Skoot
mrclean is offline   Reply With Quote
Old December 19th, 2007, 10:30 AM   #47
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
1/2" lug nuts.
Don't cut all of the inside of the driver side coil bucket off the 60 as it is support for the truss if you are keeping it.
Looking good though
Old December 19th, 2007, 06:02 PM   #48
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Looks good Skoot
C.K. is offline   Reply With Quote
Old December 19th, 2007, 06:07 PM   #49
Skooter_Built
well this shit is gettin serious!!! Just finished the first part of the rear frame chop off. Ill be honest theres something satisfing about cutting apart a perfectly good Jeep. I also roughed out the rear comp corners. Now i gotta finish cutting the rear frame so my BTF rear frame section will fit.
Old December 19th, 2007, 07:40 PM   #50
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Got a pic of the BTF rear frame section?
Old December 19th, 2007, 08:14 PM   #51
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
It's never looked better
Old December 19th, 2007, 09:15 PM   #52
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Full hydro i assume.
Unless you have a tube roller you will never get that contour from your tube fenders.
JcrOffroad
Zoom Zoom!
Old December 19th, 2007, 11:36 PM   #53
Skooter_Built
no, hydro assist. the axle needs to be pushed back like a foot or so. Im not set on that fender design, if i choose to go that route ill have a fab shop roll it like that.
Old December 24th, 2007, 06:52 AM   #54
silverxj
Recovering XJ owner
silverxj's Avatar
and this is all in your garage?
Nonetheless, looks good.
Old December 25th, 2007, 10:51 PM   #55
Skooter_Built
my parents are packrats, but its better than nothing. tomorrow ill spend some time and do a little clean up in the garage and work on the axles, while i wait on my father to wire up the welder.
Old December 25th, 2007, 11:05 PM   #56
HVYRTFT
Reed my teef
HVYRTFT's Avatar
do you have anymore stickers for it??
Old December 26th, 2007, 12:51 AM   #57
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
stickers where on it when he bought it.
Old January 3rd, 2008, 11:50 PM   #58
Skooter_Built
havent updated in a while, so heres an update. last week the welder and air compressor were hooked up so work could continue. Ive welded together the new rear frame rails, just need to do a little body work before welding them onto the frame. Ive cleaned up both axles, just need to finalize placement of the brackets and burn them in. Front suspension is mocked up, but im thinking of moving it atleast 4" more forward, but need to mock up the steering before doing anything. I made up a practice gauge cluster, needs perfection but i like it. The real one will be made out of engine turned aluminum or carbon fiber.
Right now im waiting on a few parts; Art Carr shifter, hydro assist parts, and a Premier Welder god i love Pirate. Stil need to get a 1.75 tube die before i can start the tube work.
Tomorrow im gonna put the interior back together, see where i can put a lowrance baja 540c gps, a few more gauges, a radio, comm system, cb, and a cutting brake.
oh ya, i know dirty garage, surface rust, ugly mug:chiefwoohaw::chiefwoohaw::chiefwoohaw:
Old January 14th, 2008, 10:47 PM   #59
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Nice work brother, One day if I hit the lotto Ill have to have you hook me up with some idea's
mideerslayer is offline   Reply With Quote
Old January 14th, 2008, 10:59 PM   #60
Kaiser42
Kaiser42's Avatar
lookin' good
Unimogs,LS-1,42's and a few other mod's
Kaiser42 is offline   Reply With Quote
Page generated in 3.03604 seconds with 84 queries
