Using Watts linkage with 3 Link Calculator - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2012, 11:04 PM   #1
cerial
1200PSIg Double acting
cerial's Avatar
Default Using Watts linkage with 3 Link Calculator
Getting closer to actually starting this buggy. I am going to have a triangulated 4 link(still doing the math if the lowers will be triangulated) in the front. With a 3 link in the rear running a watts linkage. It is a rear engine setup with the balancer 5" in front of the axle tube and more then enough room for almost any upper link frame mounting point. I bought a second medium truss for the rear and plan on having the top of the truss be the rotation point for the watts which will allow for more travel.
I am playing around with this 3 link calculator getting nice results using the set panhard measurements. What I can not find any info on is how to get this 3 link calculator to figure for a watts linkage and not a panhard bar.
I am sure I will do a lot of tacking, lifting, and checking when I do actually link this before it drops how I want. But, if I had a place to start from using this calculator it would cause less headaches. I have a little over a week to play around with the numbers if I can get this panhard bar issue figured out.
If I can not use the calculator I will build a mockup in Inventior and have the links set with parameters and hole positions which i can change which should work for check binding and flex but will not show any stresses or squat and roll. I might be able to add force's to the frame and stimulate hard acceleration, breaking, or cornering but I am unsure at this point.
Any help is greatly appreciated.
Old May 18th, 2012, 12:45 AM   #2
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
you would want to use a watts link....just give up already
Old May 18th, 2012, 09:34 AM   #3
Tab
Tab's Avatar
It's not on the calculator because nobody runs one. Every other person runs a normal, easy to build, panhard bar. Why do you have to make everything so difficult?
Old May 18th, 2012, 09:45 AM   #4
So, you have the engine in the back, a triangulated 4 link in the front, and a 3 link in the rear....
Can't you just take a nromal trail Jeep and drive backwards? Same thing....
Old May 18th, 2012, 09:47 AM   #5
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Wow
Old May 18th, 2012, 12:53 PM   #6
benny87
Young Gun..!
benny87's Avatar
Apparently you have WAAAAYYYYY to much time on your hands....!
benny87 is offline   Reply With Quote
Old May 18th, 2012, 01:26 PM   #7
You guys are all idiots. Don't you know that a normal 4 link doesn't have nearly enough flex? Once he gets his figured out I'm going to ask him to build one for me.
Old May 18th, 2012, 02:03 PM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Wouldn't be the first time...
JohnnyJ is online now   Reply With Quote
Old May 18th, 2012, 02:21 PM   #9
I was serious.
Page generated in 0.22834 seconds with 50 queries
