Jeep rotates but won't start - HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2012, 05:54 PM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default Jeep rotates but won't start - HELP
02 Wrangler 4.0L
Hello all, on my way to work this morning the jeep started up just fine. I was about a mile away from home when the veichle had suddenly shut off and I have no control. Luckly there was no traffic next to me so I pulled into the right lane, turn my hazzards on and got it towed home.
So far I havent found the problem, as I said, the engine will continously rotate but it wont start. The radio and everything else seems to work as well so it cant be the battery, and im assuming the alternator is fine. When I turn the ignition key, I can also hear the fuel pump turn on, so that is okay.
Im really out of ideas on what the problem could be and would really appreciate some input, thanks guys
Catnip 0_o is offline   Reply With Quote
Old May 17th, 2012, 05:55 PM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Cranks how? Fast? Slow? Does it attempt to fire? Is there gas in it? Are you sure?
Old May 17th, 2012, 06:00 PM   #3
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
well it cranks at normal speeds just as if it were to be working, which is pretty fast. it doesnt attempt to fire and I just filled the tank up 2 days ago so it has more than enough fuel
Old May 17th, 2012, 06:01 PM   #4
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Fuel pressure regulator, check and make sure you have spark, if the plugs are old, carbonized, put new plugs in it. Check the plugs first
Old May 17th, 2012, 06:04 PM   #5
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
do you have spark?
Old May 17th, 2012, 06:06 PM   #6
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
welp...this will be my first time checking spark so I have to ask, whats the best way to see if I have any spark?
Old May 17th, 2012, 08:17 PM   #7
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
could the crank position sensor cause this as well?
Old May 17th, 2012, 08:34 PM   #8
JeepManHuff
Muddin is Livin
JeepManHuff's Avatar
Yes the CPS can cause a no-start issue. First thing I'd be checking is if it has spark. If there is no spark I would definitely be leaning toward the Crank Sensor.
JeepManHuff is offline   Reply With Quote
Old May 17th, 2012, 08:51 PM   #9
itselliott
itselliott's Avatar
I had 1 CPS go bad. Pulled up to the (home) garage, had to wait for the door to fully open.........BAM,...done, CPS just quit. Had it towed to the service garage .
Old May 17th, 2012, 09:08 PM   #10
wave_crusher
I'll Direc your TV
it's kinda hard to check for spark on those, there's no wires, the coil sits right on top of all the plugs.....I'd guess pull all the plugs out, hook them into the coil, set them on the block (ground them) and turn it over. have a buddy/family member watch to see if they spark.
Edit: x2 on the crank sensor, it's on the back of the motor above the transmission i believe
Old May 18th, 2012, 07:49 PM   #11
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
so Ive been trying to locate the crank sensor but am having a really difficult time locateing it. Is this thing hard to find and is it a pain in the ass to get to?
Old May 18th, 2012, 08:27 PM   #12
mudrunner456
mudrunner456's Avatar
the crank position sensor is kind of tough to see. it should be on the drivers side towards the top of the bellhousing. two small bolts hold it in. I just had this happen to me and it was the cam position sensor, $43.00 at auto zone. I trailored it to a mechanic and in less then a minute with a scanner he told me no cam signal, easy fix.
mudrunner456 is offline   Reply With Quote
Old May 18th, 2012, 08:35 PM   #13
mudd_jumper
mudd_jumper's Avatar
Yes easy swap on either one of this. Did you have spark? I think the crank was 45 when I did it???
Old May 18th, 2012, 10:03 PM   #14
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
i found the sensor but apparently bought the wrong part, this is what I will need correct? http://www.autozone.com/autozone/par...61872_0_0_1277
Old May 18th, 2012, 10:12 PM   #15
mudd_jumper
yes that is the right senor.What is the problem?
Old May 18th, 2012, 10:43 PM   #16
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
well the part i bought must be for a different year or something, cause its just the sensor part, it doesnt have the wires attached like this one that I will need: http://www.autozone.com/autozone/par...61872_0_0_1277
The problem is that the veichle wont start and it just keeps cranking, hopefully this is the issue...
Old May 18th, 2012, 10:57 PM   #17
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
Your flooding the cylinders with fuel by constantly attempting to fire with no spark.
Replace the part (magnetic pickup aka crank sensor) before attempting anymore or you may be in danger of washing the cylinder walls with gas = bad. Only crank a few times to fire it up if it doens't start its time to get it to a mechanic.
fullthrottle is offline   Reply With Quote
Old May 20th, 2012, 10:01 AM   #18
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
well I got the old cps out and it was in real bad shape. put the new one in and it started right up :) luckly this wasnt a more expensive issue
Old May 20th, 2012, 10:53 AM   #19
capone
capone's Avatar
Great update
capone is offline   Reply With Quote
Old May 20th, 2012, 08:48 PM   #20
mudd_jumper
LOL I know that I was asking what was wrong with the part.
GREAT update. It is electronic so crap happens even if it looks ok.
Page generated in 0.43671 seconds with 83 queries
