Lift question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2012, 06:09 PM   #1
storey618
storey618's Avatar
Default Lift question
Im sixteen and don't have much money so I'm trying to find a decently cheap way to lift my zr2 Sonoma. Could I do it with shackles and torsion bar keys? I'm looking for about 2 more inches of lift what else would I need?
storey618 is offline   Reply With Quote
Old May 17th, 2012, 09:49 PM   #2
opie
www.krissplicing.com
You can crank the torsion bars, no need for keys.
Shackle or AAL for the rear. I would recommend the AAL as it retains the geometry on the drive shaft. Shackles rotate the axle and reduce the angle at the pinion. This can cause drive line vibrations.
opie is offline   Reply With Quote
Old May 17th, 2012, 10:14 PM   #3
87mopar
Web Wheeler :(
87mopar's Avatar
x2
Cranking the torsion bars will give you about 1.5-2" of lift. It will ride a bit rougher and an alignment is always good after. Try and keep the same amount of turns on each bolt. Keys are good for maybe another .5 of a inch more just a waste of money. Shackle's are never a great option but they are do-able. Add a leafs would be your best bet. Your other option would be a 2" block kit if your leafs sit on top of your axle. I dont recall how the zr2's are set up. Your ride will be a lot stiffer with aal's and torsion bars cranked.
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old May 18th, 2012, 08:06 AM   #4
storey618
storey618's Avatar
would an add a leaf kit for a 98 jimmy fit my truck?
Old May 18th, 2012, 04:16 PM   #5
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
The last thing I would recommend to anyone is to crank their tbars very high. It will shorten your front ends already short life span and will ride like a brick. And if your really lucky it will accelerate frame cracking that more than likely is already happening due the stiffer suspension.
For cheap, I hate to say it but a body lift is your best/cheapest way. I would do a 1 inch body lift with trimming and a very mild t bar crank (just enough to level the front out, if that). Then trim to run 33's.
That or pick up a used ifs lift kit (check zr2usa.com), however I feel like that is also a waste for various reasons. The best way would be to do a solid axle swap, which can be done for less than a ifs lift. Look though my build thread in my sig and send me a pm if you want a price break down on all the sas options.
Old May 23rd, 2012, 01:28 PM   #6
opie
Cranking the torsion bars does not equal a stiffer ride. You are not changing the spring rate merely the rest point of the suspension.
Sent from my MB860 using Tapatalk 2
Old May 23rd, 2012, 01:35 PM   #7
montecarlo33
The Violator
montecarlo33's Avatar
I had a zr2 blazer and I cranked the bars almost to the max and added a leaf in the rear and it rode like a tank unless I had a trailer on it, I hated it, mostly the rear end was too stiff. My vote is to crank your bars slightly, and to shackle. if you need more than get a 1 or 2" body lift after that.
montecarlo33 is online now   Reply With Quote
Page generated in 0.24464 seconds with 44 queries
