98 xj (Tomato) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2012, 07:59 AM   #1
Carbon
Yooper
Carbon's Avatar
Default 98 xj (Tomato)
Just picked up a 98 xj from Illinois. Here is my story. Drove 300 miles with the plans of driving it back to Michigan with a box full of tools and my future wife. Picked up the Jeep Monday night and pulled into the hotel, looked it over and came up with a plan. In the morning we found a gas station with air and a shady spot to work on the Jeep. First the 5 lbs of air in the tires was not going to do, so I got them up to 35 lbs. Next it needed a quick string alignment. We then took it for a ride. Hit 40 MPH and got the death wobble. Pulled into Firestone and was able to use there lift (thanks guys) found the track bar bushing was shot, steering dampener shock was wasted, ball joints were loose and pinion bearing was smoked beyond believe. I thanked the nice guys at the shop and headed to the parts store. Replaced steering dampener shock, tightened ball joints, made new bushing for track bar and checked everything over one last time. We were finally on our way home to Michigan. We thanked the guys at Napa for there sense of humor and a spot to wrench on the Jeep.
Got about 150 miles and had to remove the front drive shaft which I should have done off the start. Filled the front diff back up and headed out. Another 20 miles down the road the pinion shaft broke, locked up the front, snapped an axle and exploded a u joint on the passenger side. The pinion gear lodged itself between the ring gear and the housing and split the top of the diff. 10 MPH down the shoulder of the road to an off ramp in peshtigo we made the call for my tow dolly. Our ride showed up an hour later, loaded up and we were off down the road.
We stopped at a gas station to fuel up and grab a bite to eat then pulled out of the lot to hear a loud crash and see the Jeep along side of us. The toung of the dolled broke in half leaving only the light wires attached. We loaded the broken dolly into the truck and parked the Jeep for the night. Returned the next day with a flat bed to recover the Jeep.
Finally got it home. Pictures soon.
Carbon is offline   Reply With Quote
Old May 17th, 2012, 08:08 AM   #2
tvandyck7
OlllllllO
tvandyck7's Avatar
Sounds like a good time...
tvandyck7 is offline   Reply With Quote
Old May 17th, 2012, 08:15 AM   #3
mudrunner456
mudrunner456's Avatar
Jesus, sounds like you should have put it on the trailor from the start. Whats the plans for it?
mudrunner456 is offline   Reply With Quote
Old May 17th, 2012, 08:26 AM   #4
Carbon
Yooper
Carbon's Avatar
Well it has a 7" lift with 35's, 4.56 gears as of now. Going to get it back in drivable order, replace worn parts to start. It was an adventure thats for sure.
Old May 17th, 2012, 08:27 AM   #5
Carbon
Yooper
Carbon's Avatar
Going to be a DD/weekend toy. Mild build but we will see.
Old May 17th, 2012, 08:50 AM   #6
jerm97xj
I fixed it!!!
jerm97xj's Avatar
That sounds like a bad day. Glad you made it home ok.
jerm97xj is offline   Reply With Quote
Old May 17th, 2012, 09:20 AM   #7
Carbon
Yooper
Carbon's Avatar
I forgot how much I hate the city. Glad to be home with the Jeep. Pulled all the guts and axles out so I can drive it in the mean time.
Old May 17th, 2012, 04:12 PM   #8
Carbon
Yooper
Carbon's Avatar
Old May 18th, 2012, 06:57 AM   #9
Carbon
Yooper
Carbon's Avatar
Found a complete axle with everything but the 4.56 gears. Need to locate some.
Old May 21st, 2012, 08:31 PM   #10
Carbon
Yooper
Carbon's Avatar
Ok got the front axle out and the new one will be here tomorrow. Pulled the rear apart to replace pinion bearing and u-joints only to find out I have a chrysler 8.25. Which I hear is much better then the D35. Correct me if I am wrong. So now I have to return the rear pinion bearing for the correct one.
Old May 21st, 2012, 09:51 PM   #11
branch92
Only in a jeep
branch92's Avatar
Chry 8.25 is much bettet than 35
branch92 is offline   Reply With Quote
Old May 22nd, 2012, 07:56 AM   #12
Carbon
Yooper
Carbon's Avatar
I ordered new ring and pinion for the front. The carrier I had is junk. Can I use one from a d30 that had 3.08's? Also I noticed one tooth on the rear ring gear is worn. Should I be lookind at a new set for the rear?
Page generated in 0.31055 seconds with 59 queries
