not a truck but still a ford - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 16th, 2012, 11:12 AM   #1
72cj304
72cj304's Avatar
Default not a truck but still a ford
1990 mustang gt high idle when hot start the car it idles at about 700 rpm drive it come to a stop it idles at 1300 for a few seconds then down to 100 then back up to 1300 I have replaced the air intake temp sensor the coolant temp sensor the egr sensor both o2 sensors and the air bypass no vac leaks and no codes thanks for any help
72cj304 is offline   Reply With Quote
Old May 16th, 2012, 11:22 AM   #2
MilwaukeeF350
Dan
What about IAC sensor?
Old May 19th, 2012, 05:55 AM   #3
Cool parts peddler
Ironman Offroad's Avatar
Clean the throttle body, disconnect the battery cable for 5 min. to reset the PCM. Should clear it up.
Old May 19th, 2012, 09:15 AM   #4
tom77cj5
tom77cj5's Avatar
Tps?
Page generated in 0.21507 seconds with 35 queries
